Home > Maintenance & Modifications > Canvas rubbed through paint
hank
Common problem I believe but I've not been able to find the answer to my question...
The canvas hood has rubbed through the paintwork around the the rim of my pickup bed and cab gutter. In some places it has gone through all of the paint/primer layers right down to the bare metal so these will need acid etch priming.
My question is, will high build primer be enough to build up the lost depth where paint/primer has worn down to bare metal? Or is it going to need filler?
Post #599606 6th Feb 2017 5:21pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
In the days of galvanised cappings this didn't happen Smile
If you do paint it, isn't it just going to rub through again?
Post #599669 6th Feb 2017 8:40pm
Litch
Always been a problem but as Defender9 said, it will only rub through again.
Personally I have left mine as it is, 16-years and there is still no corrosion as the canvas is always rubbing at the surface, if I was to convert back to a hardtop again then I would have to get it dealt with as the affected area would then be exposed.
Had my cappings galvanised and they are now highly polished where the canvas rubs! ONE LIFE, GET IT!
Post #599785 7th Feb 2017 11:35am
This has also (inevitably) happened on my 2007 DC, but curiously on mine the side cappings, but not the tailgate, appear to be galvanised. I don't know at what point in production LR stopped galvanising the cappings.
I did wonder at one time if vehicles which left the factory with canvas tilts had galv cappings, whilst those that left with open bucks did not. Mine left the factory with a tilt.
It's a bit of a mystery really.
Post #599797 7th Feb 2017 12:52pm
hank
I've removed my canvas hood with the intention of leaving it off. Shouldn't rub through again as it will seldom be refitted.
My side and tailgate cappings are (mostly) rust free, it's the cab gutter/rim that has suffered rust in my case. Two spots where the sticks pass the cab gutter.
If anybody can advise on the high build primer query it would be most appreciated... Failing that I may send it to the body shop!
Post #599875 7th Feb 2017 5:13pm
