Home > My Defender > Defender 90 LS/6L80 conversion. step by step!
Page 6 of 9 <123456789>
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
Cheers Andy,
Bit more done.
Fitted the fuel tank pressure sensor in the EVAP canister. Hoses for the 2 ports there will just be hose clamped on so there should be plenty of space.
Fitted the vent valve by the filler neck. The filter on the end is up behind the mud shield that attempts to protect the back of the rear lights.
I have also now removed a metre or so of wire from the loom for them as it was too long and routed the wiring as much out of the way as I can. It was pretty dark and my phone wouldnt take a good pic by that stage
I will try and make some sort of shields for these
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #596081 24th Jan 2017 11:43pm
psimpson7
Done a bit more on this.
All the emissions hoses are now fitted.
I started going through and fitting hose clamps to everything:
Gauges have also arrived:
2014 90 XS SW 2.2.
Post #598748 2nd Feb 2017 11:21pm
psimpson7
looks pretty good I think!
2014 90 XS SW 2.2.
Post #598759 3rd Feb 2017 6:13am
Andy80
England 2008 Defender 110 Puma 2.4 HT Cairns Blue
Very OEM looking Thumbs Up
Where are you mounting the volt gauge?
Andy
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Working towards Carry on camping!
Post #598765 3rd Feb 2017 7:35am
JOW240725
Looks great! Thumbs Up James
Instagram @suffolk_rovers
Post #598773 3rd Feb 2017 9:05am
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
Dash looks great. Do you have any way to see the O2 Sensor(s) readings? It will be very helpful at the start till everything runs perfect, same with fuel pressure IMO.m
Post #598794 3rd Feb 2017 11:38am
Love the gauges!!!
Post #598795 3rd Feb 2017 11:43am
psimpson7
Thanks guys,
Fuel pressure regulator has a gauge so that aspect is done. I dont have anything to read the 02 sensors yet.
Got a bit more done
GPS Sensor for the speedo:
putting the dash back together...
Instruments connected up and go through the test sequence when ignition is on. GPS got a location within a minute or so. Dimmer for the lighting also works nicely.
I managed to strip out the unnecessary pins from the multi pin plugs for the instrument panel and reuse the required ones for the feeds, earths and lighting.
One step backwards tho..... The indicators have stopped working. Hazards are fine however. I assume I have removed something I shouldn't have in the loom. I am now doubting myself as to whether I actually tested them when I put the loom back in or if I just tested the hazards as it was quicker...
2014 90 XS SW 2.2.
Post #599006 4th Feb 2017 8:40am
Andy80
Cool How long to go to the first start?
Thumbs Up Working towards Carry on camping!
Post #599013 4th Feb 2017 9:06am
psimpson7
Its very close now but I am a bit tied up for the next few weeks so I may not get much more done till the start of March 2001 90 HT 6.0LS/6spdAuto.
2014 90 XS SW 2.2.
Post #599161 4th Feb 2017 11:11pm
JJ
United Kingdom 1987 Defender 110 V8 Petrol CSW Corris Grey
Looking forward to the video when the engine fires. HR064 Hampshire and Berkshire 4x4 Response
Post #599163 4th Feb 2017 11:14pm
psimpson7
Fixed the indicators. Fuse had gone!
Tidied up the wiring in the back of the instrument panel a bit too.
2014 90 XS SW 2.2.
Post #599451 5th Feb 2017 10:40pm
L110CDL
Great it was a simple fix Thumbs Up Clayton.
Keeper.
Post #599454 5th Feb 2017 10:42pm
psimpson7
Another bit done
Oil pressure switch adaptor for the engine which I have been waiting on a while. Interestingly this was made on a friends CNC lathe as he had his CNC VMC in bits.
I also managed to pick up a Puma 90 headlining out of a 2012 puma for $50 as the owner fitted a new one due to a couple of minor marks.
It's far better than mine was. I have already fitted the front half, but the rear will take some adjustments due to the roll cage
2014 90 XS SW 2.2.
Post #601399 13th Feb 2017 8:36am
bankz5152
Those gauges are erotic. I love them.
Post #601438 13th Feb 2017 12:22pm
