![]() | Home > Wheels & Tyres > TYRE RUB HELP AGAIN PLS ? |
NCTT Member Since: 07 Apr 2008 Location: ESSEX Posts: 229 ![]() ![]() |
ok peps , my tyres are deffo rubbing but what do th radius arms look like and how do i adjust them ?
sorry to be a pain , and if thy are rubbing will i see it on full lock , they deffo feel like it > cheers , sorry to be a pain |
top man , forgive my stupidity , will IF they are rubbing i be able to see it when they are full lock AND what exactly do i need to do , sorry im about as mechnical as a flip flop!!
IIRC to stop the offside rubbing you adjust the nearside bolt. Vice versa for the nearside wheel
Brendan |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
When you put it on full lock you will see where the tyre touched the radius arm (it will look polished where it rubs).
To adjust ^^^ As Brendan says.... you will need to screw them out to reduce lock. Turn it half a turn, give it a test, turn again if needed, test again..... until it doesn't rub ![]() Failling all that. Any Tyre/ Tracking place could do it in about 5-10 mins (I am too stingy to pay for something I can easily do myself thought). Glyn ![]() ![]() |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Just to add that if you have the vehicle lifted on a jack (remember axle stands
brilliant , many thanks indeed chaps for a super swift response !!
ARRRG NOW LORRY MAN HAS CONFUSED ME
so , obviously its gotta me done with the wheel off ?? |
![]() I did mine with the vehicle jacked up as it was easier to check the steering lock from one lock to the other and then adjust the stop locks on each side. ![]() |
but can it be done without taking the wheels off , ive only got the bottle jack it came with so i can only do 1 wheel at a time and that would defeat the object wouldnt it ?
I did mine on the ground without a jack- it just takes a little longer. All you do is put it on full lock and check it rubs. If it does durn the wheel a tiny bit straighter and then adjust the bolt (just the one side as Brendan said L/H bolt for right lock), keep doing this till it doesn't rub. when you have sorted that turning direction out then do the same for opposite lock ![]() Glyn ![]() ![]() |
fantastic , thanks vm , i shall leave u in peace
enjoy your w,e |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
Never bothered to adjust mine , when it rubbed just back off the steering a little
Dependent on the MOT inspector it might be consider a failure/advisory as wheel is fouling bodywork. A LR friendly MOT inspector might turn a blind eye to it. Otherwise spend 10 minutes before and after the MOT and it is not a problem. Brendan |
Mot's what are they
