Home > Wheels & Tyres > TYRE RUB HELP AGAIN PLS ?
NCTT
ok peps , my tyres are deffo rubbing but what do th radius arms look like and how do i adjust them ?
sorry to be a pain , and if thy are rubbing will i see it on full lock , they deffo feel like it >
cheers , sorry to be a pain
Post #59883 18th Feb 2011 5:17pm
Glynparry25
This image should help
Arrows point to the Radius arms
Circles are the two bolts that need to be adjusted (there is a lock nut on them)
HTH,
Glyn Dog :sheep:
Post #59886 18th Feb 2011 5:26pm
NCTT
top man , forgive my stupidity , will IF they are rubbing i be able to see it when they are full lock AND what exactly do i need to do , sorry im about as mechnical as a flip flop!!
Post #59899 18th Feb 2011 6:11pm
leeds
IIRC to stop the offside rubbing you adjust the nearside bolt. Vice versa for the nearside wheel
Brendan
Post #59900 18th Feb 2011 6:11pm
Glynparry25
When you put it on full lock you will see where the tyre touched the radius arm (it will look polished where it rubs).
To adjust ^^^ As Brendan says.... you will need to screw them out to reduce lock. Turn it half a turn, give it a test, turn again if needed, test again..... until it doesn't rub Very Happy
Failling all that. Any Tyre/ Tracking place could do it in about 5-10 mins (I am too stingy to pay for something I can easily do myself thought).
Glyn Dog Sheep
Post #59902 18th Feb 2011 6:16pm
Lorryman100
Just to add that if you have the vehicle lifted on a jack (remember axle stands Whistle ) remember to leave at least 20mm of clearance between the tyre wall and the radius arm to take account of the tyre bulge when lowered of the jack and the vehicle weight settles on the tyres again. Thumbs Up
Post #59903 18th Feb 2011 6:20pm
NCTT
brilliant , many thanks indeed chaps for a super swift response !! Very Happy Very Happy Very Happy
Post #59904 18th Feb 2011 6:20pm
NCTT
ARRRG NOW LORRY MAN HAS CONFUSED ME
so , obviously its gotta me done with the wheel off ??
Post #59905 18th Feb 2011 6:22pm
Lorryman100
Rolling with laughter
I did mine with the vehicle jacked up as it was easier to check the steering lock from one lock to the other and then adjust the stop locks on each side. Thumbs Up
Post #59907 18th Feb 2011 6:26pm
NCTT
but can it be done without taking the wheels off , ive only got the bottle jack it came with so i can only do 1 wheel at a time and that would defeat the object wouldnt it ?
Post #59910 18th Feb 2011 6:34pm
Glynparry25
I did mine on the ground without a jack- it just takes a little longer.
All you do is put it on full lock and check it rubs. If it does durn the wheel a tiny bit straighter and then adjust the bolt (just the one side as Brendan said L/H bolt for right lock), keep doing this till it doesn't rub. when you have sorted that turning direction out then do the same for opposite lock Smile
Glyn Dog Sheep
Post #59912 18th Feb 2011 6:42pm
NCTT
fantastic , thanks vm , i shall leave u in peace
enjoy your w,e
Post #59913 18th Feb 2011 6:43pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Never bothered to adjust mine , when it rubbed just back off the steering a little Thumbs Up it won't do any damage just shine the radius arms.
Post #59915 18th Feb 2011 6:59pm
leeds
Dependent on the MOT inspector it might be consider a failure/advisory as wheel is fouling bodywork. A LR friendly MOT inspector might turn a blind eye to it. Otherwise spend 10 minutes before and after the MOT and it is not a problem.
Brendan
Post #59917 18th Feb 2011 7:09pm
Sonic3d
Mot's what are they Rolling with laughter I struggle to keep my vehicles for one year let alone three Thumbs Up
Post #59921 18th Feb 2011 7:46pm
