Home > Technical > Rear Brakes won't bleed? 110 300tdi
moogling
Ello all
I've got a funny issue,
I've recently rebuilt all my calipers as they were past their best but the pedal is spongy as anything now it's all back together. It pumps up okay. I've bled litres of fluid through everywhere
I've clamped everything at the flexis and the pedal becomes stiff so the MC seems okay.
With the rear flexi clamped the brake pedal is normal, so it seems to be rear flexi backward.
Both rear calipers have been changed, with new pads etc. The longer brake line is also new.
No fluid is escaping and no air coming out of bleed nipples.
Any suggestions what i'm missing?
Many thanks
Matt
Post #597723 30th Jan 2017 7:22pm
Retroanaconda
Calipers on the right sides? Bleed nipple at the top?
Have you tried an Eazi-Bleed?
Post #598696 2nd Feb 2017 8:21pm
agentmulder
Kuwait
Since you're not averse to using clamps, I wonder are you clamping the front calipers while bleeding the rear? If you did that you'd get more flow through per stroke.
I've found that fluid momentum is what gets the bubbles through, so the faster and more steady you can process it the better (within reason).
Also, did you try to prime the caliper quite well before installation? I'm not sure how successful the procedure was but it made sense to me to fill it up with fluid then rotate it randomly with outlets temporarily plugged until they were on the top side then putting more fluid as the air came up.
In my case the bubbles just never ended, odd that you're seeing none, it's likely holed up at a high point? Solved the bowel problem, working on the consonants...
Post #598727 2nd Feb 2017 9:46pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
I had problems to bleed an od car - rubber brake hoses were old, metal wires in the hoses corroded (grew its diameter) and nearly closed the inner rubber tube. I was able to press the bake fluid, but not the air, and the tubes worked like one way valve, so the callipers looked like stuck. So check also the state of the hoses. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #598763 3rd Feb 2017 7:06am
jst
flexis not expanding?
as Jamies post calipers right way up?
try fast movement of fluid to shift air such as eazi bleed system. whole system like that can take 3L or so on a 90 with eazi bleed. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #598777 3rd Feb 2017 9:34am
LR90XS2011
had this on a mini and found the flexi had failed inside DEFENDER 90 TDCI XS,
Post #598884 3rd Feb 2017 7:01pm
moogling
Thanks for your suggestions all..
The issue has evolved somewhat.
I changed the flexis for Stainless goodridge ones - no change
I changed the brake master cyl, with no apparent difference. (TRW)
I noticed a crack in the servo housing and changed the servo.
Now the pedal was sinking to the floor slowly after good initial pressure.
I changed the brake master cyl AGAIN (BEARMACH)
Now the front brakes are good, BUT the rears, only get a pulse of braking power and then allowed to free wheel again. The pedal drops almost to the floor.
What am I missing here folks? I've got through 8 litres of brake fluid Big Cry
It's like the brake master cyl is only sending a little pressure down the rear circuit - when you crack the line with the pedal pushed hard down, no jet of fluid comes out. [center]
Post #605022 26th Feb 2017 6:57pm
agentmulder
Kuwait
You've changed a lot of parts, so what is left is process.
Can you describe how you bleed your brakes?
Any of the tips above help? Solved the bowel problem, working on the consonants...
Post #605033 26th Feb 2017 7:16pm
dorsetsmith
did you split rear brakes calipers to fit new seal
Post #605036 26th Feb 2017 7:27pm
moogling
Nothing above made any real difference!
I use a buddy on the pedal.and a one way bleeder. [center]
Post #605045 26th Feb 2017 7:52pm
moogling
Yup.... [center]
Post #605046 26th Feb 2017 7:52pm
Thon
Is it possibly something to do with the brake proportioning valve?
I seem to remember there is one fitted on Defenders that determines the pressure split between front and rear brake circuits?
Post #605049 26th Feb 2017 7:55pm
dorsetsmith
Post #605057 26th Feb 2017 8:11pm
moogling
Thanks for those.
I've done all the operations as described.
My system matches the 110 system correctly. [center]
Post #605074 26th Feb 2017 8:27pm
agentmulder
Kuwait
You tried clamping the front lines, and bled near to a full reservoirs fluid with great buddy to buddy timing such that the bubbles were forced past their hidey hole?
You removed and primed the caliper rotating it to let the bubbles find their way out?
If so, sorry, I'll let more knowledgeable folk chime in!
(but can report I've done the same with success..) Solved the bowel problem, working on the consonants...
Post #605153 26th Feb 2017 10:45pm
