![]() | Home > Technical > Rear Brakes won't bleed? 110 300tdi |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2688 ![]() ![]() |
Calipers on the right sides? Bleed nipple at the top?
Have you tried an Eazi-Bleed? |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Since you're not averse to using clamps, I wonder are you clamping the front calipers while bleeding the rear? If you did that you'd get more flow through per stroke.
I've found that fluid momentum is what gets the bubbles through, so the faster and more steady you can process it the better (within reason). Also, did you try to prime the caliper quite well before installation? I'm not sure how successful the procedure was but it made sense to me to fill it up with fluid then rotate it randomly with outlets temporarily plugged until they were on the top side then putting more fluid as the air came up. In my case the bubbles just never ended, odd that you're seeing none, it's likely holed up at a high point? Solved the bowel problem, working on the consonants... |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 637 ![]() ![]() ![]() |
I had problems to bleed an od car - rubber brake hoses were old, metal wires in the hoses corroded (grew its diameter) and nearly closed the inner rubber tube. I was able to press the bake fluid, but not the air, and the tubes worked like one way valve, so the callipers looked like stuck. So check also the state of the hoses. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8155 ![]() ![]() ![]() |
flexis not expanding?
as Jamies post calipers right way up? try fast movement of fluid to shift air such as eazi bleed system. whole system like that can take 3L or so on a 90 with eazi bleed. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 ![]() ![]() ![]() |
had this on a mini and found the flexi had failed inside DEFENDER 90 TDCI XS,
moogling Member Since: 29 Apr 2015 Location: Surrey Posts: 12 ![]() ![]() |
Thanks for your suggestions all..
The issue has evolved somewhat. I changed the flexis for Stainless goodridge ones - no change I changed the brake master cyl, with no apparent difference. (TRW) I noticed a crack in the servo housing and changed the servo. Now the pedal was sinking to the floor slowly after good initial pressure. I changed the brake master cyl AGAIN (BEARMACH) Now the front brakes are good, BUT the rears, only get a pulse of braking power and then allowed to free wheel again. The pedal drops almost to the floor. What am I missing here folks? I've got through 8 litres of brake fluid ![]() It's like the brake master cyl is only sending a little pressure down the rear circuit - when you crack the line with the pedal pushed hard down, no jet of fluid comes out. [center] ![]() Click image to enlarge |
You've changed a lot of parts, so what is left is process.
Can you describe how you bleed your brakes? Any of the tips above help? Solved the bowel problem, working on the consonants... |
did you split rear brakes calipers to fit new seal
Nothing above made any real difference! I use a buddy on the pedal.and a one way bleeder. [center] ![]() Click image to enlarge |
Yup.... [center] ![]() Click image to enlarge |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
Is it possibly something to do with the brake proportioning valve?
I seem to remember there is one fitted on Defenders that determines the pressure split between front and rear brake circuits? |
![]() Click image to enlarge ![]() Click image to enlarge |
Thanks for those.
I've done all the operations as described. My system matches the 110 system correctly. [center] ![]() Click image to enlarge |
You tried clamping the front lines, and bled near to a full reservoirs fluid with great buddy to buddy timing such that the bubbles were forced past their hidey hole?
You removed and primed the caliper rotating it to let the bubbles find their way out? If so, sorry, I'll let more knowledgeable folk chime in! (but can report I've done the same with success..) Solved the bowel problem, working on the consonants... |
