![]() | Home > Puma (Tdci) > Fitting Single Arm Rear Wheel Carrier |
Sell it and buy a Mantec carrier ... or wait 18 months, then remove the single arm carrier, and fit a Mantec
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8191 ![]() ![]() ![]() |
from look of the plate, i would say yes you are correct it goes inside the cross member, two of them?
spacers fit between the crossmember plates i would guess - presume some long bolts came with it? just line up bolts andpush spacer up into space whilst trying to locate bolt into spacer, magnets can help and a good torch! and patience. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
jzk841 Member Since: 25 Jan 2016 Location: Rothbury, Northumberland Posts: 14 ![]() ![]() ![]() |
Thanks James, I had thought it would require a bit of patience ! just wasnt sure. Both plates are similar, same overall size, one has a a cut out square section on the bottom, the one in the photo does not.
cheers |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 287 ![]() ![]() ![]() |
One plate goes to the Outside of the Crossmember the other to the Inside, The Crush Cans go inside the Crossmember, lots of struggling to get them to fit, you may have to reduce them in length to get them to fit, the bolts go through the Crush Cans. If you shorten the Crush Cans repaint the ends and refit with lots of Grease followed by some Dinitrol or similar. NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
Thanks Norman
cut out one prob goes inside, to clear exhuast hanger on some models maybe? Cheers
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 ![]() ![]() ![]() |
these are a sod to fit, but Paul at TMD sent me some instructions, if you PM me your email ill send you a copy.
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 ![]() |
Standard on most defender accessories ![]() |
Thanks All... I got some instructions from Ben at TMD, they also sent me the right sized Spacers
Well done, perseverance paid off NormanD WE191
