Home > Puma (Tdci) > Fitting Single Arm Rear Wheel Carrier
jzk841
United Kingdom 2008 Defender 90 Puma 2.4 CSW Tonga Green
Hi All, Im feeling a little inadequate in the knowledge department so thought Id ask you lot !
I have a TMD Single Arm rear Wheel Carrier (made by Safari Equip I believe) I have a couple of questions as it has no fitting instructions
1) there are two plates that come with it, I think they are backing plates that fit to the back of the Cross member can you confirm this ?
2) I have a bunch of what look like short sections of pipe ! (I think they are Crush cans, by reading on the forums) How do you get them into the Cross member to sit between the plates and the bolts to then go through ? (if that is correct !)
3) I have to enlarge some holes in the Xmember I was going to use a HSS Cobalt drill ? will that work ok ?
4) Why cant it come with instructions !
Thanks for your help....
Jon
Post #597211 29th Jan 2017 10:15am
Sell it and buy a Mantec carrier ... or wait 18 months, then remove the single arm carrier, and fit a Mantec
Post #597299 29th Jan 2017 2:23pm
jst
from look of the plate, i would say yes you are correct it goes inside the cross member, two of them?
spacers fit between the crossmember plates i would guess - presume some long bolts came with it?
just line up bolts andpush spacer up into space whilst trying to locate bolt into spacer, magnets can help and a good torch! and patience. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #597304 29th Jan 2017 2:44pm
jzk841
Thanks James, I had thought it would require a bit of patience ! just wasnt sure. Both plates are similar, same overall size, one has a a cut out square section on the bottom, the one in the photo does not.
cheers
Post #597327 29th Jan 2017 4:06pm
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
One plate goes to the Outside of the Crossmember the other to the Inside, The Crush Cans go inside the Crossmember, lots of struggling to get them to fit, you may have to reduce them in length to get them to fit, the bolts go through the Crush Cans. If you shorten the Crush Cans repaint the ends and refit with lots of Grease followed by some Dinitrol or similar. NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #597349 29th Jan 2017 4:51pm
jzk841
Thanks Norman
Post #597377 29th Jan 2017 5:49pm
jst
cut out one prob goes inside, to clear exhuast hanger on some models maybe? Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #598032 31st Jan 2017 2:47pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
these are a sod to fit, but Paul at TMD sent me some instructions, if you PM me your email ill send you a copy.
Post #598254 1st Feb 2017 12:25pm
pjb
Re: Fitting Single Arm Rear Wheel Carrier
Standard on most defender accessories Rolling with laughter 2020 P300 HSE
Post #598265 1st Feb 2017 1:41pm
jzk841
Thanks All... I got some instructions from Ben at TMD, they also sent me the right sized Spacers Smile I can confirm it was a SOD to FIT ! but it is now in place and looks good, the rear door actually closes without a gap !
Post #598641 2nd Feb 2017 5:42pm
NormanD
Well done, perseverance paid off NormanD WE191
2015 110 XS Utility
Post #598642 2nd Feb 2017 5:46pm
