![]() | Home > Puma (Tdci) > How much play is in your steering shaft UJs? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17717 ![]() ![]() ![]() |
Mine has had a very small amount of movement in the upper UJ for about the last three years, and each time I expecty it to fail the MOT test becuasse of this, but it's not yet been spotted (I haven't fixed it because I think it is an interesting test of the tester - it *should* fail, but is not at all easy to detect).
I have a couple of spare shafts put aside ready for the day ot does fail. You can also tell that the movement is there on some bumpy surfaces when there is a perceptible "knock" in the column. Fortunately the MOT tester's route with the Tapley meter for the brake test is smoot, so this doesn't happen. Curiously although I first found the movement about three years ago, it hasn't got any worse since (and three years is about 100k miles for me) and I wonder if it has always been there from new. Inceidentally the only difference between the upper shaft for a TDCi and a TD5 (apart from a huge difference in proce) is the heat shield round the top joint rubber member. The purpose of the shield is to protect the joint from the heat from the cat (or DPF/cat on a 2.2, I guess) and it does mean that however tempting it is due to the price difference, a TD5 column should not be fitted to a Puma. |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 673 ![]() ![]() ![]() |
Mine has a little play also. My indy assures me it is perfectly normal and due to the rubber in cylindrical bit just below the upper uj.
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Mine is def in the UJ.
If it were a prop shaft I'd be replacing, but I see it's sold as an assembly with next to nought user 'tampering' allowed. Might see how it goes over the next three years! And yes I read about the heat shield Td5 no no too ![]() |
It's common rather than normal, and there should be no play anywhere in the upper column. Mine is the top UJ as well, my initial thought was that being in a warm play the assembly grease (if there is any) dries out. Since it hasn't got any worse in a very high mileage, I am now inclined to think it just wasn't very good to start with.
As long as it is minimal, doesn't affect the steering, and you keep an eye on it, I don't think you need to worry. If it fails an MOT type test, then change it. The two spares I have were both 2nd hand ex-breaker and are fine, they were about a tenner each, vastly cheaper than the excruciating price of new genuine. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20746 ![]() ![]() |
How much new? WeWillWinπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
LRJ £ 220 + 20% + P&P
Blimey, I was expecting even more though to be honest!
No doubt a resold part with LR label worth £100 stuck to it? WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
The Britpart version is classed as 'OEM' and with cast parts (like flanges) the blue box hasn't been too bad..
But then again, it is steering we're talking about ![]() |
Britpart and a safety critical item.
![]() β½οΈπ’οΈβοΈπ§°πͺ |
The annoying thing is that the TD5 part, which is exactly the same except for the crappy little heat shield, is abour £40 iirc.
tobz102 Member Since: 07 Feb 2014 Location: Atherstone Posts: 134 ![]() ![]() ![]() |
I believe I got an OEM one for £150 from LRDirect
I haven't the vehicle to look at at the moment but would it be possible to use the heat shield from the old puma shaft on a new Td5 shaft?
Or have they designed it such that would be taking the failing UJ(s) along for the ride? Solved the bowel problem, working on the consonants... |
Unfortunately it is not removable - the shaft cannot be dismantled at all.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8213 ![]() ![]() ![]() |
could you not fit a pre puma shaft and do away with the rubber bit? Cheers
