Home > Maintenance & Modifications > What is the best shaker can spray for a rear cross member?
gilarion
I was wondering what is the best shaker can spray for a rear cross member. Mine needs a little bit of cosmetic care as my dogs have scratched it when jumping in and out (not for the first time). I usually use Hammerite satin black, and while it gives a good finish and is very similar to the original OEM black, it takes ages to dry, especially in cold weather, it says on the can up to fifteen minutes to dry but really takes a lot longer .
So what have you used? For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #597670 30th Jan 2017 4:59pm
ibexman
I used plasticote good results
Post #597671 30th Jan 2017 5:01pm
Balvaig
Halfords Satin black aerosol. A good match
Post #597672 30th Jan 2017 5:02pm
xtr2turbo
United Kingdom 2016 Defender 110 Puma 2.2 USW Corris Grey
I find that the best quality spray comes from the UPOL cans.
Post #597682 30th Jan 2017 5:35pm
Bluest
Buzzweld CIO would be my chocice having used it on some other bits. 2007 110 TDCi Station Wagon XS
Post #597691 30th Jan 2017 6:05pm
grafty99
+1 for buzzweld Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #597693 30th Jan 2017 6:06pm
Romadog
Buzzweld CIO Thumbs Up
Post #597707 30th Jan 2017 6:29pm
ethanicus
2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Hammerite smooth satin black worked a treat on my old defender and lasted years. looked like new.
Post #597709 30th Jan 2017 6:33pm
JOW240725
Buzzweld CIO, on Buzzweld RCP undercoat if necessary Thumbs Up James
Instagram @suffolk_rovers
Post #597736 30th Jan 2017 7:47pm
I like Upol paints too, if looking for something tough but decent looking I'd consider Stonehchip or a rubberised paint.
Other than stat stick to decent paint, if you have a decent amount of clearcoats layer down you may be able to polish out.
But you can only go so far just the once with that obviously. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #597745 30th Jan 2017 7:52pm
BossHog
I need to do the rear mud flap brackets also at the same time as the cross member as the paint coating is just peeling off the brackets. Would you paint them all at the same time with what ever your using, reason I ask is they look a different colour black ?
Post #597757 30th Jan 2017 8:04pm
Devon-Rover
For a rattle can solution then Wurth stone guard as a flexible base coat, then you can overpaint with a more traditional paint to your own taste and colour.
I did this to the rear crossmember of my old 90 before I sold it and it came out really nice with a layer of Simoniz Tough black over the top.
Thumbs Up
Post #597758 30th Jan 2017 8:05pm
Mwd
I used Isopon Zinc 182 primer (recommended by a blacksmith), followed by Halfords Satin Black on the visible parts of my rear crossmember and mudflap brackets. It looks pretty good but I don't know how long it will last given that I can't access the other side of the crossmember to protect it.
When I had the car professionally under guarded & waxoyled they 'resprayed' the rear crossmember as part of the job (for no extra charge). I'm glad I didn't pay for it because the rust started reappearing within weeks! I know very little about car finishes but when I was preparing the crossmember to spray it myself, I rubbed it down and then degreased /removed the dust with methylated spirits and the black finish the body shop used dissolved in the meths! There was no primer and the black paint seemed to be about as robust as marker pen ink. Perhaps the body shop was aiming for an OE factory finish on the crossmember?!
Post #597768 30th Jan 2017 8:25pm
