Home > Puma (Tdci) > Coolant leaking around expansion tank cap.
Bluest
I seem to be losing a small amount of coolant out of fill cap on the expansion tank. There is always a small amount of coolant on the outside of the tank around the cap. It leaks enough that I do have to add a bit of coolant between service, not a lot, but it does bother me. Faulty cap or a sign of serious impending doom? 2007 110 TDCi Station Wagon XS
Post #597372 29th Jan 2017 6:38pm
Change the cap, IIRC they have a PRV built in that can go haywire.
They are quite cheap. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #597375 29th Jan 2017 6:42pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Common issue, as Steve says the cap is knackered.
Replace it .... and it's one of the few items where a pattern part is better than genuine Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #597380 29th Jan 2017 6:57pm
Bluest
Any particular make of aftermarket cap? Google only shows Britpart... 2007 110 TDCi Station Wagon XS
Post #597403 29th Jan 2017 7:45pm
Genuine isn't very expensive, I bought one myself last year.
Try Dan @ Duckworth parts.
Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #597437 29th Jan 2017 8:39pm
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
When I bought mine it leaked so I bough a new cap and it still leaked, so I bought another cap and that too still leaked. In the end I bought a new coolant tank and all has been OK since then so it was not the cap!!!!
At least I have some spare caps now! Cheers Don.
Post #597662 30th Jan 2017 5:29pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
True! Mine stopped leaking once I fitted a britpart cap in dispair! (had previously replaced with two genuine ones and it was still leaking...) β€œA Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #597663 30th Jan 2017 5:35pm
Bluest
Because I'm a glutton for punishment, I've ordered a genuine one, £10. If it doesn't work I'll go Britpart. 2007 110 TDCi Station Wagon XS
Post #597703 30th Jan 2017 7:24pm
AlanH
Australia
My 2010 110 leaks and has done for the last 173K (kays not miles) and I've never bothered replacing it. Every time I topped up the expansion tank it promptly lost about 2cm but never any more.
I've reached the conclusion that that is the correct level and just left it.
AlanH.
Post #597955 31st Jan 2017 9:59am
pme
United Kingdom 2007 Defender 90 Puma 2.4 SW Tonga Green
HI
exactly the same issue on my 2007 2.4, did look like the expansion vessel initially but bought the cheapest cap i could find as a quick check, 3.75 on ebay. Put it on about 2k ago, perfect.
Post #598648 2nd Feb 2017 6:56pm
Bluest
My luxurious £10 genuine Land Rover one arrived today. I'll let you know if it works. If not I'll get a cheapo and one. 2007 110 TDCi Station Wagon XS
Post #598658 2nd Feb 2017 7:32pm
Fat Cog
My 2008 Puma did it from new, had the cap changed under warranty but it continued to leak for the 9 years or ownership & it never really bothered me...no leaks so far on my 2016...repeat so far!!!! Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #598661 2nd Feb 2017 7:45pm
Naks
the coolant cap should be considered as a service item, and changed every year Thumbs Up --
Post #598771 3rd Feb 2017 9:45am
Bluest
New genuine cap seems to have rectified the issue. Did a few hours driving yesterday and no sign of leakage. Wonder how long it will last? 2007 110 TDCi Station Wagon XS
Post #599228 5th Feb 2017 1:44pm
ericvv
Really? Original factory cap, and never had a leak in more than 8 years.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #599266 5th Feb 2017 4:14pm
