![]() | Home > Puma (Tdci) > Coolant leaking around expansion tank cap. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20706 ![]() ![]() |
Change the cap, IIRC they have a PRV built in that can go haywire.
They are quite cheap. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Common issue, as Steve says the cap is knackered.
Replace it .... and it's one of the few items where a pattern part is better than genuine ![]() |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4254 ![]() ![]() ![]() |
Any particular make of aftermarket cap? Google only shows Britpart... 2007 110 TDCi Station Wagon XS
Genuine isn't very expensive, I bought one myself last year.
Try Dan @ Duckworth parts. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 ![]() ![]() ![]() |
When I bought mine it leaked so I bough a new cap and it still leaked, so I bought another cap and that too still leaked. In the end I bought a new coolant tank and all has been OK since then so it was not the cap!!!!
At least I have some spare caps now! Cheers Don. |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 564 ![]() ![]() ![]() |
True! Mine stopped leaking once I fitted a britpart cap in dispair! (had previously replaced with two genuine ones and it was still leaking...) βA Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, [β¦] it's up to you to do justice to your Land Rover!β - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
Because I'm a glutton for punishment, I've ordered a genuine one, £10. If it doesn't work I'll go Britpart. 2007 110 TDCi Station Wagon XS
AlanH Member Since: 15 Mar 2010 Location: WA Posts: 242 ![]() ![]() |
My 2010 110 leaks and has done for the last 173K (kays not miles) and I've never bothered replacing it. Every time I topped up the expansion tank it promptly lost about 2cm but never any more.
I've reached the conclusion that that is the correct level and just left it. AlanH. |
pme Member Since: 06 Jan 2016 Location: cambridge and mainly ariege Posts: 49 ![]() ![]() ![]() |
HI
exactly the same issue on my 2007 2.4, did look like the expansion vessel initially but bought the cheapest cap i could find as a quick check, 3.75 on ebay. Put it on about 2k ago, perfect. |
My luxurious £10 genuine Land Rover one arrived today. I'll let you know if it works. If not I'll get a cheapo and one. 2007 110 TDCi Station Wagon XS
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 ![]() ![]() ![]() |
My 2008 Puma did it from new, had the cap changed under warranty but it continued to leak for the 9 years or ownership & it never really bothered me...no leaks so far on my 2016...repeat so far!!!! Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2668 ![]() ![]() ![]() |
the coolant cap should be considered as a service item, and changed every year
![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
New genuine cap seems to have rectified the issue. Did a few hours driving yesterday and no sign of leakage. Wonder how long it will last? 2007 110 TDCi Station Wagon XS
Really? Original factory cap, and never had a leak in more than 8 years. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
