Home > Td5 > Door won't unlock.
plumpmoose
Door won't unlock.
Turn key, but it won't lift the internal button, so remains locked. Squirted wd40 in obvious places and the button moves a little, but not enough to unlock. What should I do?? Hardly use my lrd, but needed all day tomorrow!!
Post #596825 27th Jan 2017 6:53pm
bogwert
Scotland 2003 Defender 90 Td5 CSW Zambezi Silver
How cold is it?
Could be a case that the mechanism is frozen up?
If not then I would suggest getting in from the other side, opening it and taking the door cover off, see if any wires are stretched or loose.
Try giving everything a once over with White Grease? Chris
2014 Discovery 4 TDV6 HSE
2003 Defender 90 TD5 CSW
Post #596831 27th Jan 2017 7:12pm
VVS210
Use the other door then reach across & lift the locking indicator from the inside. Seem to remember something similar happened to mine a few years back & there was a broken plate inside which meant that turning the key moved the linkage but didn't unlock.
Razz beaten to the post!
Post #596832 27th Jan 2017 7:14pm
plumpmoose
I can't lift the button either. Looks like it's the internal door panel off job. How easy is that?
Post #596837 27th Jan 2017 7:19pm
VVS210
It won't be easy as from memory the door card lifts off over the locking indicator which means you'll need to pull the trim clips out all round & the door really needs to be open to do that... You might be able to pry the door card out enough to get at the mechanism to open the door?
Post #596845 27th Jan 2017 8:01pm
I had exactly the same with mine last week. Couldn't unlock with the key nor by lifting the button. I'd resigned myself to struggling with the door card but had a 'determined' jiggle of the internal handle and, all of a sudden, it opened! Gotta be worth a try. Darren
Post #596881 27th Jan 2017 9:49pm
L90DNY
United Kingdom 2006 Defender 90 Td5 HT Corris Grey
I had this once before and one of the rods had become slightly bent, so wasn't moving the lock far enough. Will be a struggle with the door closed tho to get the door card off or at it.
That plastic button is made up of three pieces from memory, a housing that is held by 2 screws into the top of the door, you put the the long 'button' through that which you hook onto the rod connecting to the lock mechanism and then a more external housing that sits in the door card, which can just slide up.
The trouble is it will be very hard to get the door card off with the door locked shut, if you have a wind up window, removing that by the small clip and the internal handle, you might be able to prior the door card off at the top to get a look at whats going on behind.
I guess another option is to take the door completely off at the hinges.
Another time it got stuck, I just gave the handle a bash from the out side and it free'd up something and let me open it. From pushing the button in whilst it was locked, made something stick, giving a bit of knock free'd it up and the key would turn.
Good luck with yours !
Post #597131 28th Jan 2017 10:02pm
I'm not sure that taking off at the hinges will be easy as the lock will still be locked onto the frame. Darren
Post #597134 28th Jan 2017 10:09pm
Play with the door pin and handle at the same time from inside, I get this occasionally on the passenger door if the button outside is pushed once locked.
You go to unlock it and you can only open from inside. No Guts, No Glory.
Post #597135 28th Jan 2017 10:10pm
plumpmoose
Ok, gave lrd a good clean today (snow foam, 2 buckets and power wash rinse) and tried lock again. Did not work first time, but then moved enough to open door. Once open I have locked and unlocked many times and problem seemed to have resolved itself.
Think I will take door card off on a dry day and check round for any gremlins.
Thanks for you suggestions.
Post #597286 29th Jan 2017 1:53pm
Balvaig
A couple of things to try before you remove the door card:
Give the lock mechanism a good flush out with WD 40 and re lubricate with light silicone spray
Check that the door is not closing too tightly and putting undue pressure on the latch, which may have prevented it from opening
If you do remove the door card make certain you have spare clips, as you may well break some if you remove it in this cold spell
Post #597295 29th Jan 2017 2:12pm
