Home > Tdi > Heater hot and cold
simons17
Heater hot and cold
Hi all
Any one come across the heater blowing hot then cold and then hot again?
Temperature guage is steady at half way . Not sure if I have fault or just need a muff for the grill. My thoughts is the viscous fan is over cooling the rad, until the engine opens the thermostat
Any thoughts
Simon w
Post #596573 26th Jan 2017 9:51pm
g-mack
Post #596575 26th Jan 2017 9:54pm
simons17
I'll try and bleed it through and see if that helps. thanks .
Post #596580 26th Jan 2017 10:02pm
Blackhat90
Scotland 1995 Defender 90 300 Tdi HT Epsom Green
Hi " is it the 300tdi., I took my fan off years ago, never needs it, even in the summer,[ towing 2.5tons too ], sounds like you've lost coolant, check the level, and monitor level, to see if using - losing, coolant Wink
Post #596835 27th Jan 2017 7:16pm
