Home > Technical > TDCi Blank Switch Removal on Centre Dash |
If you do not mind ruining DUMMY SWITCH, with a self-tapping screw and then pull Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
24th Jan 2017 12:32pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
Take the radio out is one option (if you have keys) 1988 90 Td5 NAS soft top
2015 D90 XS SW |
24th Jan 2017 12:33pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17372 |
The switch blanks just clip into place and can be popped out if you use a small screwdriver carefully. You may find that there is a connector and wiring tucked into the back of the switch blank, depending on which one you remove and the age of your vehicle, since quite often the harnesses include the connectors for extras which are not fitted. (My dash, for example, has the wiring for front foglights, HRW, and a few other things which have never been fitted to the vehicle.)
24th Jan 2017 12:35pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20348 |
Use some stiff wire with a small hook on the end or two, should work as a puller. $W33T $0U7H3RN $UG4R
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
24th Jan 2017 1:03pm |
Michaels Defender Member Since: 16 Aug 2007 Location: North Yorkshire Posts: 269 |
Thanks, I will have a go with a screwdriver this evening and try to pop it out, I was not sure if the switch was on the inside and the switch cover was on the outside and they clipped together
Michael |
24th Jan 2017 1:09pm |
Just took a píc for you, press fit really, and come out easily.
It's just the fact there is nothing to get any purchase on to get it out. Click image to enlarge $W33T $0U7H3RN $UG4R 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
24th Jan 2017 1:26pm |
