Home > Technical > TDCi Blank Switch Removal on Centre Dash
Michaels Defender
United Kingdom 2013 Defender 110 V8 Petrol XS CSW Auto Orkney Grey
Hope you can help, I am wanting to remove the blank switch on the centre dashboard, can this be done without removing the centre console?, if so does any one know how
Michael
Post #595860 24th Jan 2017 12:03pm
dgardel
Italy
If you do not mind ruining DUMMY SWITCH, with a self-tapping screw and then pull Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #595870 24th Jan 2017 12:32pm
Martin
Site Admin
Take the radio out is one option (if you have keys)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #595871 24th Jan 2017 12:33pm
The switch blanks just clip into place and can be popped out if you use a small screwdriver carefully. You may find that there is a connector and wiring tucked into the back of the switch blank, depending on which one you remove and the age of your vehicle, since quite often the harnesses include the connectors for extras which are not fitted. (My dash, for example, has the wiring for front foglights, HRW, and a few other things which have never been fitted to the vehicle.)
Post #595872 24th Jan 2017 12:35pm
Use some stiff wire with a small hook on the end or two, should work as a puller. $W33T $0U7H3RN $UG4R
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #595876 24th Jan 2017 1:03pm
Michaels Defender
Thanks, I will have a go with a screwdriver this evening and try to pop it out, I was not sure if the switch was on the inside and the switch cover was on the outside and they clipped together
Michael
Post #595878 24th Jan 2017 1:09pm
Just took a píc for you, press fit really, and come out easily.
It's just the fact there is nothing to get any purchase on to get it out.
Post #595882 24th Jan 2017 1:26pm
