Home > In Car Electronics > Show us your Anderson connection
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
Had a Anderson on the front and rear of my last defender but was just bolted to the bumper and always looking a little Heath Robinson
Looking for ideas of a more professional fitting
Post #595731 23rd Jan 2017 9:07pm
Seatbox floor pan but underneath? Should be out of sight, but relatively dry, but reachable.
I think there are caps / covers you can get too.
I've known and seen others with one in a locking wingtop faux vent too. KEEP CALM AND Drill ON
Post #595737 23rd Jan 2017 9:11pm
Sphere
Thumbs Up
I have seen the vent to really like that idea but the boxes seam expensive.
Post #595740 23rd Jan 2017 9:14pm
L110CDL
Iv'e got mine behind my middle seat with a cover on the end and about a metre length so can go out any of the two doors Whistle Clayton.
Keeper.
Post #595765 23rd Jan 2017 10:17pm
mk1collector
Gmb do a lockable box that fits in the unused air vent on top of the drivers wing and I remember seeing pics on here of someone fitting the connector in the box. It was a while ago and I can't remember who did it but it looked neat and protected from the elements until needed. Ray
My build thread
Post #595767 23rd Jan 2017 10:23pm
Capt_Steve
England 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Post #595783 23rd Jan 2017 11:03pm
mk1collector
Yeah that's the gmb one I was on about. Someone (on here I think) fitted their Anderson connectors inside Thumbs Up Ray
My build thread
Post #595786 23rd Jan 2017 11:09pm
JOHNT01670
United Kingdom 2006 Defender 90 Td5 SW Zermatt Silver
As I have to unbolt my 3rd party seats to access the battery I fitted one inside the battery box with access point below the front passenger seat base to provide quick access should I flatten the battery again - and also used for my solar trickle charge connection when not in use. 2006 TD5
2002 Honda Transalp 650
1995 Yamaha Vmax 1200
2014 Nissan Juke (wifes)
Post #599351 5th Feb 2017 7:31pm
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
I have Mazda RX8 seats fitted so getting to my battery is a faff (4 bolts to undo - oh the pain).
So, as i'm always jumping people (ooooh errrr misses), I thought i'd mount my anderson connector externally. I took my positive from the starter motor and the ground to same point as my winch. I'm quite anal on ruining my lines and sticking things on willy-nilly. So, this is almost a covert install... but since upgrading to a full size intercooler, i'm going to have to move it Sad
 TD5 Defender 90
Discovery 3 HSE
Post #599585 6th Feb 2017 2:14pm
VeeTee
Netherlands
^ Do you have switch between starter and connector or is it always live? Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #599602 6th Feb 2017 3:58pm
huffhuff
The correct answer would be yes, there is a switch. However, that switch is still in a box waiting to be fitted. My idea was to have it simply in the engine bay or possibly hinge the spare wingtop vent and have it in there (locked) TD5 Defender 90
Discovery 3 HSE
Post #599611 6th Feb 2017 4:51pm
VeeTee
Netherlands
I would not do without a switch... It would be to easy for a scumb@g to cause a short circuit and start fireworks...
I also took the feed for my winch from the starter an so I used a switch in this (locked) wingtop box. Not cheap but excellent quality.
 Cheers, Vincent
MySite
Post #599615 6th Feb 2017 5:12pm
huffhuff
Where did you get the box VeeTee?
Thanks TD5 Defender 90
Discovery 3 HSE
Post #599826 7th Feb 2017 1:18pm
VeeTee
Netherlands
http://www.mudstuff.co.uk/gmb-fender-locker.html Cheers, Vincent
MySite
Post #599828 7th Feb 2017 1:21pm
L110CDL
I also used the switch that does the winch as well for my Anderson connector Thumbs Up Clayton.
Keeper.
Post #600243 8th Feb 2017 10:33pm
