Home > In Car Electronics > Radio wiring,
Procta
Radio wiring,
Did all defenders come Radios standard? The radio doesn't work at all, and it only has 3 wires going to power the full works up.
I have this for some ones handy work for the speaker wiring which looks like its been retrofitted
 Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #595030 21st Jan 2017 5:42pm
dorsetsmith
not all spec defenders have radio fitted to start with
Post #595040 21st Jan 2017 6:12pm
Definitely retrofitted but they have fitted ISO plugs.
I'd remove those bullet connectors solder and heatshrink though...
You really need aMultimeter to do some fault finding testing. Thumbs Up $W33T $0U7H3RN $UG4R
Post #595050 21st Jan 2017 7:11pm
Procta
steve funny you should say that, the speaker loom that is shown, looks like its a second hand unit, so I will just replace it and solder the joins. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #595069 21st Jan 2017 8:12pm
Don't blame you, definitely check the power feeds and that they are correctly fused.
If it's someone else's work and they didn't know what they are doing then you never know if it's fused!
They obviousky avoided going any soldering so my guess is it's either DIY or a quick job by Halfords or similar place quite quickly. $W33T $0U7H3RN $UG4R
Post #595080 21st Jan 2017 8:27pm
Procta
what ever they have done, looks like it may have done the interior light system. The radio would make a weird noise, and I am pretty sure it was what drained the battery.
Looks I will have some right old work to do, One project I had to change a full car loom due to someone's handy work! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #595182 22nd Jan 2017 1:58am
