Home > In Car Electronics > Which alarm would you recommend?
andy---doe
Is there an alarm on the market that is way better than the rest?
What should I consider?
I have just had a quote for a Clifford Category 1 Alarm - £599 Fitted. Is this a good choice or can you point me in a better direction?
Post #594987 21st Jan 2017 4:01pm
grafty99
To be honest the factory alarm does most things an aftermarket one will and is already installed, it just needs activating Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #594996 21st Jan 2017 4:21pm
andy---doe
Please explain
Post #595011 21st Jan 2017 4:43pm
jaydt
2011 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I had a Clifford avant guard 5.5 (tilt sensor ,blackjack and perimeter sensors) and couldn't recommend enough. Had it fitted after the horse had bolted ( a grands worth of led spots and light bar) it's paid for itself as another attempt through back door soon tripped the alarm and scared the crap out of the toe rag when I looked back at security cameras.
Post #595078 21st Jan 2017 8:23pm
grafty99
All defenders have the alarm module as standard, it is required to give the ecu a code to start. It can be activated by computer (nanocom or similar) to enable the engine to be immobilised doors to be protected etc.
With a few parts such as bonnet switch, battery backup sounder and interior sensor it will protect all opening panels and detect interior movement with very little wiring indeed.
In fact depending on the age of your defender everything but the interior motion sensor will be plug and play. Just need to have it activated on computer and have some fobs synced up Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #595161 22nd Jan 2017 12:07am
andy---doe
Grafty99 -
I would be more than happy to go down that route if there were people/companies that I could trust to do the necessary work, but I wouldn’t know where to start looking and I sure don’t have the knowledge to do it!
If anybody knows anywhere in South Yorkshire, please let me know, otherwise I will continue looking for ‘off the shelf’ replacement alarms recommendations and fitters.
Post #595243 22nd Jan 2017 10:32am
grafty99
I'm not sure who is near you. Irb developments could certainly do it but are based in Birmingham. You could try b.a.s I'm thing they are more northern Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #595250 22nd Jan 2017 10:55am
grafty99
Yes b.a.s are based just outside York. Pete is a site sponsor on here and I'm sure could do the work. Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #595253 22nd Jan 2017 11:00am
andy---doe
Thanks - if I can't get anybody closer I will call him
Post #595362 22nd Jan 2017 6:12pm
