Home > Puma (Tdci) > middle row seats on 110 csw
Caterham
being paranoid a polisher, fussy etc I subconsciously go round looking for problems - or so it seems.
just had the car back after the seat brackets being replaced because the paint had gone off on holiday leaving rust behind (you get the picture) - same problem with the rear mud flaps.
anyway my problem (or so I think) is that the middle row seats now seem to have a load of play in them / seem loose that I don't remember.
basically if you jump in the boot and hold the top / head rest of the middle row seats you can move them back and forth (just the seat back) by about half an inch / 1 cm. I thought they were solid before. Can anyone confirm if this is normal please.
thanks.
Post #59451 16th Feb 2011 8:53pm
Lorryman100
Did they replace the little rubber squares (Glued onto the body which the seat stops rest on), after replacing the new brackets?
Post #59467 16th Feb 2011 9:27pm
Caterham
thanks mate - I presume youre talking about the two 'platforms' the seats sit on top off?
the platform has a square rubber pad and the seat has a round rubber post and they should make contact - mine dont quite touch 1-2mm gap. however not sure if this is still the case while I'm sat on the seat cause I can't see?
either way not sure this is the issue as its the seat back that has the play in it not so much the base?
Post #59484 16th Feb 2011 10:45pm
Zagato
Did they treat the rust or just paint over it?
These are little jobs you could do yourself properly and have the satisfaction that you have worked on your Landy and done it right Thumbs Up It also lessens the risk factor of leaving your pride and joy with possible herberts - who know what goes on Whistle Well, we all know what goes on sometimes Rolling Eyes
Post #59509 17th Feb 2011 8:20am
Caterham
not sure - I think they were rubbed down.
......and if only I had the time Sad
Post #59513 17th Feb 2011 8:28am
Caterham
ij think I've found the problem (another job for the weekend).
the brackets that have been painted that the seats hinge forward on are slotted so they mounting height is adjustable. well it would appear they are circa 2-3 mm too high.
I'll let you know how I get on over the weekend.
Post #59785 18th Feb 2011 8:30am
