Home > In Car Electronics > Window lift switch connector shells/inserts
Does anyone know where I could get hold of s number (ideally four) of the white 6-way connectors to fit the electric windows switches (YUF101521LNF) -
(Photo courtesy of PaulMc via an older thread)
The part number above is the number for the switch, not the connector shell. I believe that the shell is YPC113220 and is an AMP Multilock part, at least the receptacles are AMP Multilock.
For some reason this connector appears to be as common as the proverbial rocking-horse doings.
PaulMc mentioned in a post some while ago on this forum that he had some, but he hasn't read the PM I sent some time ago (it's still in my Outbox so hasn't been read) - does anyone know if he's still active on the forum?
Thanks!
Post #592703 13th Jan 2017 9:13am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Looks like a "Multi-lock 070 6 pin Female Connector" maybe?
First hit on google: http://www.cycleterminal.com/amp-multilock-070.html โ€œA Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, [โ€ฆ] it's up to you to do justice to your Land Rover!โ€ - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #592711 13th Jan 2017 9:35am
Martin
Site Admin
If you get stuck I can get them in white or black rather than the pale green  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #592743 13th Jan 2017 11:03am
Thanks guys, I must have spent nearly a day trying (unsuccessfully) to find those on the internet!
Post #592763 13th Jan 2017 12:34pm
rallysteve
Post #592768 13th Jan 2017 12:44pm
Thanks everyone, I have now ordered some up from simtekuk.
Most grateful! Thumbs Up
Post #592771 13th Jan 2017 12:58pm
Martin
Site Admin
Sad
I'll add some to the site shop  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #592791 13th Jan 2017 1:55pm
Sorry Martin if I misread the tenor of your email, I took it to mean that you'd rather not bother if I could get some elsewhere, but were willing to get some if I was stuck! I dodn't mean to cause a glum face!
With the number of people now who reconfigure their dashboards, add electric windows, etc, having a selection of these on the forum shop would I feel be a populer move.
Thank you, and sorry!
Post #592803 13th Jan 2017 2:13pm
Martin
Site Admin
No worries, I'll be stocking these from Monday Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #592810 13th Jan 2017 2:27pm
Martin - You should put up for sale Econoseal and Superseal connectors too.
They are always in demand for various things, I'm sure they would sell.
Plus of course the OE type of connectors like BW was looking for.
Thumbs Up $W33T $0U7H3RN $UG4R
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #592834 13th Jan 2017 3:50pm
Stiff1
I too have been trying to reach PaulMc for some time without any success.
Are there male connectors to these to create a plug and play loom for the extension of some of the dash switches on the TDCi ie. rear wash and wipe as well as front and rear heated screens or should I just cut off the existing plugs and extend the wires?
All help appreciated.
Post #593117 14th Jan 2017 10:23pm
An update to this thread.....
The window lift switch connectors are in fact NOT AMP Multi-lock 070 6 pin Female Connectors as suggested above, because the ones I ordered have arrived and are much smaller than those required! Big Cry
Martin, I will now be ordering from the forum shop after all! I presume that the ones you list are in fact the correct ones, not the same incorrect Multi-lock 070 ones I bought from Simtek.
Post #594312 19th Jan 2017 8:33am
Martin
Site Admin
Hold off and I will double-check mine Surprised  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #594318 19th Jan 2017 8:53am
Martin
Site Admin
I've got a switch off my Puma and the connectors I have got look right. I will confirm in an hour when I get to the connectors themselves.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #594325 19th Jan 2017 9:33am
Martin
Site Admin
Nope my ones are too small as well Big Cry
I will track down the correct ones if I can.
Martin  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #594340 19th Jan 2017 10:20am
