Home > In Car Electronics > Window lift switch connector shells/inserts
Page 2 of 2 <12
rallysteve
PaulMC gives the impression that they were AMP Multilock 070 here:
http://www.defendersource.com/forum/f6/lat...395-3.html
If you are retrofitting the electric windows then I suggest using discovery 1 switches which look identical but have normal sized spade terminals (if you cut the molded housings from a discovery loom you should be able to reuse with new terminals
Post #594458 19th Jan 2017 3:08pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Unfortunately they are too small, a tad to narrow and the pins are closer together. I bought some, and they don't fit, however I'm using discovery 2 rear door switches, although I thought they were the same. never mind, I'll just get some female connecters that join these, which I know are available, and they'll come in use for something.
Could you let us know if you manage to find some Martin?
I'm struggling to find a scrap yard that will let me have the connectors without buying the whole loom at 100x the price!! Big Cry
Post #594462 19th Jan 2017 3:20pm
Page 2 of 2 <12
