Home > Puma (Tdci) > oil coming from rear axle outer flange |
ROBBONTHEROCK Member Since: 23 Jun 2014 Location: Aberdeenshire Posts: 637 |
Likely the inner seal on the axle stub.
Not a hard job, biggest issue you will have is the brake caliper bolts. If you decide you need to stage an intervention, then I would buy new caliper bolts and a seal kit, bolts are cheap and they can be a to get off, so can be damaged, hence why I would replace. But before doing any of that, I wouldcheck the axle vent isn't blocked....but I would still have money on the inner seal. Question is, do you do the whole hog and replace the bearings as well, I probably would, along with drive flanges as well..... Cheers Andy |
9th Jan 2017 7:21pm |
thrasher Member Since: 04 Jan 2017 Location: isle of arran Posts: 17 |
cheers andy,will probably replace bearings aswell,i will check breather pipe as there must be a reason for it to happen,im going to do the outer flanges as well will see how it goes, I don't use it every day so being of the road not a big deal
9th Jan 2017 8:34pm |
