Home > Technical > Wiper issues (changed everything) still problems! HELP!
FLX1S
United Kingdom 1992 Defender 90 2.5 n/a Diesel SW Bonatti Grey
Hi All,
I have a 1992 Defender and having wiper issues. Intermittent not working and they don't park. Grrr
Done everything:
- Read through the previous posts.
- New park switch.
- New motor.
- New drive cable.
- New wiper boxes.
- New wiper spindles.
- New wiper arms.
- New wiper blades.
- New Lucas stalk!
But still they don't work on intermittent nor will they park.
Advice please??
Thanks
Paul
Post #591525 9th Jan 2017 11:03am
VVS210
Have you replaced the relay?
Post #591527 9th Jan 2017 11:09am
FLX1S
I did a about 6 months ago with a programable one...
Post #591531 9th Jan 2017 11:21am
VVS210
Try sticking the old one back in if they were working properly when you took it out... If not stick a new standard one in & see what happens.
Post #591534 9th Jan 2017 11:26am
FLX1S
Old one went in the bin, so just ordered a Lucas one...
Thanks, I'm guessing its all it can be?
Post #591602 9th Jan 2017 5:29pm
mk1collector
May have got a dodgy park switch. Ray
My build thread
Post #591655 9th Jan 2017 8:26pm
Huttopia
Have you tried hitting it and swearing a lot? I find it doesn't necessarily fix the problem but it does make you feel better for a bit.
Post #591663 9th Jan 2017 8:53pm
dgardel
Italy
Cables? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #591734 9th Jan 2017 11:30pm
FLX1S
Relay changed, and no change. Still doesnt park or work on intermittent!
Hitting and swearing now starting!
Anymore ideas?
Post #592435 12th Jan 2017 1:06pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Take the park switch off but leave the cables connected. Operate it manualy to see if it works while the wipers are running.
This will show if any issue between the gears and the park switch.
Post #592472 12th Jan 2017 2:46pm
mk1collector
 Ray
My build thread
Post #592483 12th Jan 2017 3:51pm
Martin
Site Admin
What does work with them?
Do they wipe when you wash?
Do both speeds work from the stalk?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #592493 12th Jan 2017 4:20pm
FLX1S
they wipe on both speeds, don't park, nor work intermittently.
They don't wipe when you spray the washer either.
I'm thinking wiring!
Post #592511 12th Jan 2017 5:58pm
FLX1S
Post #593526 16th Jan 2017 3:24pm
Froglaise
Not much else to change so must be a wiring issue.
Did you add/change anything on the vehicle before the problem started?
Post #593531 16th Jan 2017 4:02pm
