Home > Technical > Wiper issues (changed everything) still problems! HELP! |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 |
Have you replaced the relay?
9th Jan 2017 11:09am |
FLX1S Member Since: 17 Dec 2016 Location: North Wales Posts: 10 |
I did a about 6 months ago with a programable one...
9th Jan 2017 11:21am |
Try sticking the old one back in if they were working properly when you took it out... If not stick a new standard one in & see what happens.
9th Jan 2017 11:26am |
Old one went in the bin, so just ordered a Lucas one...
Thanks, I'm guessing its all it can be? |
9th Jan 2017 5:29pm |
May have got a dodgy park switch. Ray
9th Jan 2017 8:26pm |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1977 |
Have you tried hitting it and swearing a lot? I find it doesn't necessarily fix the problem but it does make you feel better for a bit.
9th Jan 2017 8:53pm |
Cables? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
9th Jan 2017 11:30pm |
Relay changed, and no change. Still doesnt park or work on intermittent!
Hitting and swearing now starting! Anymore ideas? Cheers |
12th Jan 2017 1:06pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 670 |
Take the park switch off but leave the cables connected. Operate it manualy to see if it works while the wipers are running.
This will show if any issue between the gears and the park switch. |
12th Jan 2017 2:46pm |
Ray My build thread http://www.defender2.net/forum/topic17615.html |
12th Jan 2017 3:51pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6621 |
What does work with them?
Do they wipe when you wash? Do both speeds work from the stalk? 1988 90 Td5 NAS soft top 2015 D90 XS SW |
12th Jan 2017 4:20pm |
they wipe on both speeds, don't park, nor work intermittently.
They don't wipe when you spray the washer either. I'm thinking wiring! |
12th Jan 2017 5:58pm |
16th Jan 2017 3:24pm |
Froglaise Member Since: 24 Sep 2016 Location: left forum Posts: 212 |
Not much else to change so must be a wiring issue.
Did you add/change anything on the vehicle before the problem started? |
16th Jan 2017 4:02pm |
