Home > My Defender > Defender 90 LS/6L80 conversion. step by step!
Page 5 of 9 <123456789>
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
Never had a problem with the ignition leads on mine but have melted some air line that was sat on top of the chassis so had to put a heat shield around that - it's a good 4-5 inches away from the manifold where it melted through so they certainly throw out some heat ! http://www.yorkshireoffroadclub.net/
Post #583095 6th Dec 2016 4:02pm
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
Cheers for the tips guys.
One other thing I did yesterday was to draw up the pump setup so I can run an intank pump inside the std td5 tank.
It looks a bit complicated but its not really. 2 8mm holes for the electrical bulkhead connectors, 2 m5 caphead holes to hold the spacers, 3 m16 ports to allow the fitment of m16-6an adaptors for the feed, return and a breather as required, and a Standard 5 bolt SAE pattern to allow the fitment of a Fuel Level Capacitance Universal Sender.
On the underneath of the middle m16 port is another one on a boss to allow the fitment of an M16-3/8 barb to allow the connection to the pump with submersible fuel hose
This should be made this week.
I am looking at one of these to simplify the fuel gauge:
http://www.speedhut.com/ecommerce/product/...ender-(3-5
I was going to try and use the standard instruments but I am now thinking about possibly using this gauge set (black bezel, GT Font, bar tick style):
http://www.speedhut.com/kit/GRM4-6KITGPS-0...hift-light
I am wary of the costs adding up however as its already cost a fair bit to get this far!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #583139 6th Dec 2016 8:40pm
davew
You could always use a Discovery 300TDi pickup and an external pump... it'll also make it much easier when you have to add a second fuel tank Smile http://www.yorkshireoffroadclub.net/
Post #583157 6th Dec 2016 10:23pm
psimpson7
Done a few more small things.
Mounts for the radiator are made up. Will weld these in shortly.
Gauge set from speedhut is ordered.
GPS speedo with inbuilt revcounter, canbus water temp, oil pressure and voltmeter, and a fuel gauge with capacitance sender. I was hoping the combination speedo and rev counter would also be available with canbus as the trip meter screen can be used to read and clear fault codes!! It isnt unfortunately. only the single gauges for those.
I also found a problem with the Lokar gear cable. It isn't getting the range of movement it is supposed to be
The inner should push in about 20mm more at this end.
I emailed lokar and they are sending me a new cable. This has slowed progress a bit however
Some more wiring:
2014 90 XS SW 2.2.
Post #585476 15th Dec 2016 11:26pm
psimpson7
Done a bit more.
Fan fitted.
Power steering pump -> steering box lines and fittings done.
Billet fuel rails.
Most of the rest of the fuel system is on order.
Main wiring harness is simplified as much as I think I can so will refit that soon.
2014 90 XS SW 2.2.
Post #586473 20th Dec 2016 5:50am
psimpson7
Replacement gear cable turned up from Lokar (Excellent service)
This one works perfectly:
Also sorted out the upper radiator mounts.
Interior progress:
Fuel pressure regulator also arrived along with a heap of fittings.
I have a heap more stuff on order for the fuel system including about a dozen more fittings and 7m of 200series hose, the evap valve and cannister and a few other bits and pieces
2014 90 XS SW 2.2.
Post #589641 3rd Jan 2017 1:15am
LR90XS2011
brilliant DEFENDER 90 TDCI XS,
Post #589644 3rd Jan 2017 6:43am
L110CDL
+ 1 Thumbs Up Clayton.
Keeper.
Post #590246 4th Jan 2017 9:47pm
psimpson7
Thanks Guys,
Done a little bit more as stuff arrives.
Fuel lines done including the bypass regulator at the outlets of the rails into the return line. I have an inline filter after the pump aswell.
2014 90 XS SW 2.2.
Post #590605 6th Jan 2017 7:10am
Nice details going on Cool
Post #590607 6th Jan 2017 7:12am
psimpson7
Thanks Greeni!
Everything seems to take so long now! Even the small stuff which you can hardly see.
Having said that I also fitted some much larger items over the last few days including all the front end panel work and the engine cover
Starting to look a lot more complete now. Sorry for the rubbish pictures.
Couple more pics showing the air intake roughly set up. Need to feed both rocker breathers into this between the MAF and TB. I have a 3/8 aluminium barb which I will fit into the aluminum joiner tube that connects the 45 and 90 degree hoses. I am not sure if the K+N filter will stay but for now it will do.
I have also finished the powersteering hoses so thats one thing that is actually completely finished!
I need to order about 30 hose clamps now and go over all the hoses.
2014 90 XS SW 2.2.
Post #591697 9th Jan 2017 10:02pm
Looking well. I know how much time the small things consume. It took one night after work to sort the air intake, measure it up and draw how it would go, then find and order things online!!
I spent far too long lining up fresh jubilee clips, I'm not really OCD, but I thought I might as well get it looking right.
Post #591709 9th Jan 2017 10:25pm
Pickles
Engine cover looks good,..gives it the "factory" look.
Too many leave 'em off, even in Aussie, where LS 1,2,& 3 are common, many modified engines are minus the engine cover, which looks "untidy",..imho.
Pickles.
Post #591731 9th Jan 2017 11:23pm
psimpson7
Thanks Pickles.
I had been doing some research on how to set up the emissions stuff. I wasn't really sure and confused myself a bit but I think I have it nailed now.
Basically
Tank breather ---> Larger connection of pair on EVAP canister
Smaller connection on EVAP canister ---> Purge valve on Engine
Fuel tank pressure sensor (to read pressure from fuel system - I will probably fit this in the EVAP canister)
Vent valve ---> larger connection on own on EVAP canister
Filter line on Vent valve ----> vents to atmosphere.
When the engine is off this allows the tank to release pressure out of the system via the filter line.
When the engine is running it feeds the tank emissions through the EVAP canister, then to the purge valve which when it sees fit releases it into the throttle body.
I also have to change a couple of electrical connectors. The fuel tank pressure sensor plug was wrong. It looked like it should use the identical looking e85 fuel flex sensor type plug so I ordered one of those (I could get this locally so figured it was worth a gamble).
Typically the shape of the plug was very slightly different so I tweaked it with a dremel and file. The pin spacing and height luckily was 100%
I then swapped the plug over.
This is the one that was on the loom.
You can see the sensor in the background.
New connector pins:
Need to change the one on the vent valve section of loom next.
2014 90 XS SW 2.2.
Post #595516 23rd Jan 2017 7:19am
Andy80
England 2008 Defender 110 Puma 2.4 HT Cairns Blue
I like how your 90 looks, could be (and was) just Td5 hardtop with tube wings and roll cage!
Everyone loves a sleeper!!! Thumbs Up Working towards Carry on camping!
Post #595519 23rd Jan 2017 7:55am
