Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4800 ![]() ![]() ![]() |
I purchased a Nextbase Dash Cam 312GW from Halfords for £75.00 down from £99.00. I chose that model after seeing forum member "Sticklepaths" footage he posted with one of these cameras and I was impressed with the clarity even compared to the Gopro cameras I use alot for work.
![]() 2008 SVX 90 2000 XS TD5 90 |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10958 ![]() ![]() |
![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Put a fresh coat of Maguiars on the tires. Bit shiny, but it will matt down over two weeks. Most important is that this tire shine avoids the antiozonant, a component of all tires these days, to turn the tires brown. A good tire shine every 2 months or so is all it takes to avoid that from ever happening.
Eric ![]() Click image to enlarge ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Cant beat Maguiars ericvv imo
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20734 ![]() ![]() |
Eric - is that one in the purple bottle I used not so long ago?
Careful using it before MOT, you'll be trying too hard and they might get slippy and fail. ![]() ![]() ⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
Well, I apply it only on the sidewall, not on the rolling section of the tire.
![]() Purple bottle indeed. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Going to be fitting this bundle of joy later this evening
![]() ![]() Click image to enlarge |
Wild Card 90 Member Since: 03 Dec 2014 Location: Gerlingen Posts: 1060 ![]() ![]() ![]() |
Windscreen washer reservoir ??? ....with quad
![]() 2008 Td4 90 SW, 2012 2.2 90 SW, 2" raised Trailmaster/Terrafirma Heavy Track Raids, 255 MT´s, Recaro CS´s, anorak, wellingtons |
No messin!
Optic delivery system for when you REALLY need a shot
![]() My build thread http://www.defender2.net/forum/topic17615.html |
Got it fitted, walked in the garage right after work and came out of the garage at 10pm. I just need to fit the fuel filter housing....that should be it.
I do get sick of spannering sometimes!! Last night was spent fixing a neighbours Ford C-Max in the freezing darkness, it's rear tailgate lock solenoid was crapping itself, then as soon as I did that, I stripped his door down on his 110 and fixed a lock issue on that too ! |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
^^ Need to put your prices up!
![]() Self confessed mileage hunter ![]() |
Hahahahahaha I do it as I'm a good neighbour!!
AndyB Member Since: 10 Nov 2016 Location: North Wales Posts: 37 ![]() ![]() |
What did I do today...
Wired up the heated seats in our 1989 90! It was bloomin damp and orrible outside!! Our toasty arses should make up for it though!! Dead posh us now, heated seats AND electric heated windscreen...... no stereo in it yet, mind. Perhaps by next week if bits arrive though!! Andy |
