![]() | Home > Td5 > Turbo oil drain pipe weeping. Gasket? 2001 TD5 90 |
MC84 Member Since: 22 May 2016 Location: Near Bristol Posts: 360 ![]() ![]() ![]() |
My oil drain pipe from the turbo to the sump is weeping at the turbo end. Is there a gasket I can change to prevent this? If there is, is this the part number? ERR2109
Thanks. Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
Looks as if you are right. I'm going to order and fit the bit in a week or two and will update you on the progress Vogler. Thanks for the heads up...
![]() ![]() Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
have look at the link below
http://www.allbrit.de/UNI.cfm?PAGE=751080&SPRACHE=EN |
Many thanks, that's what I'll order
Try not to be like me in spending 20 minutes digging out all my Allen keys and Torx keys trying to find the right one to undo the fixing I thought I could feel holding the pipe onto the turbo. Turned out that the "hole" I could feel was actually the hole that the normal hex head bolt had fallen out from
JWL, mine still have the 10mm bolt heads showing but thanks for the tip
bifterx Member Since: 29 Nov 2014 Location: North Wiltshire Posts: 33 ![]() ![]() ![]() |
Yeah, did mine a few months back. Didn't totally eliminate it but tons better - I think ,y track has has a remap in the past to crankcase pressure higher. I'm going to fit a provent to to deal with the excess oil. Disco 300TDi XS - Gone
Disco 3 SE manual - Gone 😭 Freelander 2 SE manual Defender 110 TD5 DC |
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 ![]() ![]() ![]() |
Did mine yesterday. I have only driven 50 miles since in various traffic and highway, but it looks promising: no leak until now.
J |
Hi, i did mine just before Christmas after giving the mating surfaces a really good clean and so far so good, no leaks. Thanks for the info on the correct part as well! Mike
