Home > Td5 > Turbo oil drain pipe weeping. Gasket? 2001 TD5 90 |
MC84 Member Since: 22 May 2016 Location: Near Bristol Posts: 360 |
My oil drain pipe from the turbo to the sump is weeping at the turbo end. Is there a gasket I can change to prevent this? If there is, is this the part number? ERR2109
Thanks. Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
4th Dec 2016 4:22pm |
Looks as if you are right. I'm going to order and fit the bit in a week or two and will update you on the progress Vogler. Thanks for the heads up... Mike
4th Dec 2016 5:26pm |
have look at the link below
http://www.allbrit.de/UNI.cfm?PAGE=751080&SPRACHE=EN |
4th Dec 2016 6:35pm |
Many thanks, that's what I'll order Mike
4th Dec 2016 7:45pm |
Try not to be like me in spending 20 minutes digging out all my Allen keys and Torx keys trying to find the right one to undo the fixing I thought I could feel holding the pipe onto the turbo. Turned out that the "hole" I could feel was actually the hole that the normal hex head bolt had fallen out from
4th Dec 2016 9:13pm |
JWL, mine still have the 10mm bolt heads showing but thanks for the tip Mike
5th Dec 2016 8:41am |
bifterx Member Since: 29 Nov 2014 Location: North Wiltshire Posts: 33 |
Yeah, did mine a few months back. Didn't totally eliminate it but tons better - I think ,y track has has a remap in the past to crankcase pressure higher. I'm going to fit a provent to to deal with the excess oil. Disco 300TDi XS - Gone
Disco 3 SE manual - Gone 😭 Freelander 2 SE manual Defender 110 TD5 DC |
9th Dec 2016 9:31pm |
Vogler Member Since: 02 Nov 2014 Location: Brussels Posts: 309 |
Did mine yesterday. I have only driven 50 miles since in various traffic and highway, but it looks promising: no leak until now.
J |
11th Dec 2016 3:58pm |
Hi, i did mine just before Christmas after giving the mating surfaces a really good clean and so far so good, no leaks. Thanks for the info on the correct part as well! Mike
4th Jan 2017 8:47am |
