Home > Maintenance & Modifications > Roof tent on a pick up tub?
Surrey Rover
I quite fancy a roof tent but owning a 90 pickup don't want to go to the hassle and expense of buying a full length Hannibal or equivelent roof rack for the few times I will use the roof tent. So has anyone seen one spanning the rear tub of a pickup on some kind of low down frame?
I know I could get a fabricator to make something up but don't really want to go to the expense so looking for a nice easy solution or none at all.
Thanks for your thoughts.
Post #58943 13th Feb 2011 11:42pm
leeds
Thinking aloud.
What size is the rear tub?
What I am thinking, 3 roof bars across tub then a folding rooftent mounted to roof bars ?
Would need to check packed sizes of tent in comparison to rear tub
Brendan
Post #58950 14th Feb 2011 12:08am
Laurie
I did it on my Series III about 20 years ago.
Fitted a sheet of plywood over the rear body held onto the capping rail with J bolts. Then fixed the tent to that.
Padlocks on the tailgate underneath made everything secure.
I'll see if I can find a photo.
Post #58988 14th Feb 2011 12:20pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
This was on my old 110 just to give you an idea of overhang etc Thumbs Up
Post #58990 14th Feb 2011 12:23pm
BigMike
you could have brackets fabricated and mount a 90cm patriot to the top of the tub. Other option is fit a roll cage over the back and put the tent on that
Post #59006 14th Feb 2011 1:14pm
TC
If you wanted to avoid an over hang then a fabricated cage works a treat. Have a look at my gallery Thumbs Up
Post #59028 14th Feb 2011 3:16pm
Surrey Rover
That is exactly what I had in mind, do you have any further pictures of it or could let me know how it was fixed, it looks like you have a tub cover on it and then some kind of bracket fixing kit?
Thanks
Post #59067 14th Feb 2011 6:25pm
Surrey Rover
Love your truck TC, very tidy. Yours actually got me thinking about it but as you had it fabricated I guessed it would be a lot of cost and hassle to get it fixed up. Reading various posts ai think you bought it from Sonic? So maybe he could answer vote questions Smile
Post #59070 14th Feb 2011 6:27pm
TC
I take no credit for it Surrey, Sonic built it for his Defender, I just swooped in and vultured it when he finished with it Thumbs Up
I liked what Sonic did above, but I wanted to avoid the cost. I bet you could come up with a solution involving roof bars over the tub, you would though be dealing with an overhang....queue Ali Sport wheel carrier Whistle To fill the void under the tent.
The other consideration about mounting it low, you won't have the ability to use the space below it when the tent is up, no tourer kit etc. You may end up wanting to come up with a solution for an awning for useable living space after you have mounted the tent.
I haven't used my set up yet so whatever you do, don't take my views as sound! The best advice I have recieved is to take it slowly, think through your uses and build slowly.
My truck is just about getting to the point where I can use it for camping trips, nothing more. I want to have a truly self sufficient overland set up but that is a while and a few quid away yet Thumbs Up
Post #59083 14th Feb 2011 7:07pm
Sonic3d
Hi Surrey Rover
There are some more pics in my gallery showing the various setups ive had Thumbs Up The one in the pic above shows an African Outback cover on the tub which had 2 roof bars for the tent to sit on. As for tents I've had all types Inc an off road camper trailer, and not one is perfect all the time. As Steve says if you mount it down low you won't have any standing room under it unless your 3ft tall Rolling with laughter
Post #59106 14th Feb 2011 8:05pm
