Home > Maintenance & Modifications > Front bumpers
Procta
Front bumpers
is there a difference between the rubber end cap ones and the older ones? My dad thinks there is, god knows why.
I am looking at getting a later bumper that's all for mine, ( its rotten) Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #589446 2nd Jan 2017 2:17pm
Green Machine
The newer ones have holes in the ends for the rubber end caps. That's the only difference as far as I'm aware. But if you're buying a replacement consider an aftermarket HD bumper which are made of much stronger stuff than standard and therefore may actually protect the front of the bodywork in an impact. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #589450 2nd Jan 2017 2:38pm
gilarion
You can fit an older style bumper (often they are much cheaper) as the rubber end caps will still fit, however you will have to drill four holes to each end cap to fit the fir tree fastners. It is easy to do just fit the end caps on to the old style bumper and then just drill out the holes using the rubber end cap holes as a guide. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #589452 2nd Jan 2017 2:49pm
Procta
Spot on, where do you get HD bumpers? Smile Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #589455 2nd Jan 2017 3:26pm
gilarion
You could look here. Some examples are not cheap though.
https://www.firstfour.co.uk/shop/non-winch...ty-bumpers For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #589457 2nd Jan 2017 3:50pm
Procta
spot on, not that expensive really compared to the rear bumper options for these. I might just bite the bullet and buy one of these, If I am going to get something new, it might as well decent and solid.
My dad said that the rubber capped ones are weaker? I cannot see how like Confused Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #589461 2nd Jan 2017 4:21pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
^^ I have seen people mention that newer bumpers are thinner and weaker than older older ones.
I have also seen people say that a thicker front bumper is more likely to result in a bent chassis, in the event of a front collision.
( I am currently thinking of upgrading to a HD front bumper, with built in front recovery points)
Post #589485 2nd Jan 2017 5:49pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
I think I am right in saying that the rubber end caps are only fitted on passenger carrying models (station wagons), and not commercials - for some reason? Euro-Leafing to infinity and beyond.....
Post #589511 2nd Jan 2017 6:26pm
Fifth Horseman
That may be true, certainly my old 110DC didn't have them from new. Although I have seen many with them fitted that may have been by the owners.
Post #589530 2nd Jan 2017 6:54pm
apt100
It may have changed at a certain age? A quick browse through the approved used list seems to show all hard tops with the end caps. Some have had new grills etc so may have been owner upgraded. But this example is a 2012 and probably the "plainest" example and it has them fitted
http://www.usedvehicles.landrover.co.uk/search#/details/2733964
Post #589535 2nd Jan 2017 7:13pm
Green Machine
I think at one point (during the Td5 era) higher spec models had the end caps i.e. County and XS, but base spec didn't. At some point it changed so that they all had end caps. My Dad has a 2012 base spec 90 pick up which has them, so perhaps it changed with the 2.2 engine. 2005 Td5 | 90 Station Wagon | Tonga Green
Post #589542 2nd Jan 2017 7:32pm
shipbadger
United Kingdom 2011 Defender 110 Puma 2.4 HCPU Galway Green
My 2.4 Puma Hi-cap has rubber end caps. Don't know why but in the back of my mind something says it was to meet a regulation concerning pedestrian safety. Can't think of any other reason for adding them.
Post #589545 2nd Jan 2017 7:43pm
williamthedog
My poverty spec pick up had them.
Being the standard bumper is made of cheese I replaced it with a D44 one instead Thumbs Up
Post #589550 2nd Jan 2017 7:49pm
Wandathe110
I cannot recommend Ian dixons products enough, he does a large selection
of H/D (6mm) standard style bumpers to winch bumpers to rock sliders.
Look at this on eBay http://www.ebay.co.uk/itm/172442351972
This is similar to the one I bought from him only mine has a military style towing point built in too
Post #589552 2nd Jan 2017 7:52pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I have just replaced my front bumper with a Firstfour bumper https://www.firstfour.co.uk/defender-heavy-duty-bumper-2.html , I could pick the original one up with one hand the Firstfour one I needed help lifting.
The only problem I had was that the tolerances of the Firstfour bumper are tight and it needed a bit of persuasion from a rubber mallet to get it over the chassis. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #589696 3rd Jan 2017 12:03pm
