Home > In Car Electronics > Additional switch locations... Help
big110
2014 Defender 110 Puma 2.2 SW Keswick Green
2014 puma.
I'm about to install a compressor and front and rear locker switches and need a spot for these switches. I feel like the dash pod causes too much view restriction in an already tight/small viewing window.
I'm thinking the blank side areas to the left and right of the radio may be best option. The spot commonly used for the double din relocation of switches.
My questions:
Does a template or Bezle exist to add a group of switches to that area?
How do Carlings mount? Looks like a square hole must be cut.
The other option I thought could be behind my knees while sitting in the drivers seat. Currently have a batt cutoff coming through the seat box and could add a shallow box to mount switches I guess
Any guidance is very helpful
Post #588605 30th Dec 2016 4:31am
ericvv
Post #588606 30th Dec 2016 5:23am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Cor4x4
http://www.davidecorsetti.com/prodotti.php?id_cat1=12
First Four
https://www.firstfour.co.uk/defender-double-switch-bezel.html Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #588615 30th Dec 2016 7:59am
Mo Murphy
Mine are on the cubby box using the Mud switch mount.
50 Shades of Pennine Grey
Post #588630 30th Dec 2016 9:27am
robtd590
United Kingdom 2003 Defender 90 Td5 HT Oslo Blue
addional switches
Hi all,
Needing to fit some additional switches into my defender, I would like to use the genuine switches but does anyone know where I can get the switch holders?
Post #588961 31st Dec 2016 3:04pm
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
I've got the FCX twin din for 1 set of 7 carling switches, plus the other din with a Whelen OptiDin switch panel. I've got the raptor dash pod with another 7 switches in.
I also have the MUD roof console,that could take 7 switches, but I've used it for a radio.
There is also the MUD dash kit where the passenger handle is for another din sized slot, or alternatively the cubby box mug holder inserts.
Another option I was looking at are these: http://www.ebay.co.uk/itm/231848689785?_tr...EBIDX%3AIT
Anyone tried them before? North Cumbria Search and Rescue - Team Leader
Post #588988 31st Dec 2016 4:59pm
Theater
Re: addional switches
Theater wrote:
First Four
http://www.defender2.net/forum/topic49880.html
Land Rover Discovery 2 SWITCH CARRIER ( 2 ) - Part Number : AWR1159LNF
http://www.brit-car.co.uk/product.php/1083..._dis11_rrc
If you have a Defender Td5, you can fit two of these " Land Rover Discovery 2 SWITCH CARRIER" perfectly on the center of the dash.....
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Marco
Post #589014 31st Dec 2016 5:53pm
robtd590
Thanks for the info
Post #589074 31st Dec 2016 7:56pm
Theater
I found some pictures :
PaulMc wrote:
A 6-switch carrier is fitted to the Discovery-2 -
Two of these carriers can be fitted into a DIN aperture -
http://www.defender2.net/forum/topic36107.html
Post #589407 2nd Jan 2017 11:05am
