Home > Maintenance & Modifications > Battery failing?
AMBxx
Battery failing?
My 110 XS SW is about 18 months olds. About 6 months ago, I left the inside light on and flattened the battery. All appears to work OK, but lately if I start the engine, reverse out of the garage, then turn off, I get a warning sound when I start the engine for the 2nd time.
I understand that this is a battery warning.
Looking at my tracker data, the battery had been dropping down to about 12.2V. Charges at 14V, then drops to about 13-13.5V when stopped again.
Is the battery failing, or is it just the cold weather? Seems like very short battery life, but I may have damaged the battery when it was discharged by the internal light.
Post #588143 28th Dec 2016 1:53pm
The discharge doesn't help but it's normal to get quite a voltage drop.
Even more so in cold weather and doing short trips, starting draws more current and will drain more than anything and twice in a row cold will drop it even further.
I personally wouldn't worry.
My genuine battery is 6+ years old and still going strong, so I doubt it's finished and probably wants a good run with alternator charging current with no other draw on it such as heated seats, lights etc etc. No Guts, No Glory.
Post #588167 28th Dec 2016 3:03pm
LR90XS2011
take it off give it a good shake refit and charge for several hours it will probably be fine for a good few years DEFENDER 90 TDCI XS,
Post #588205 28th Dec 2016 5:36pm
discomog
I normally only use my Defender at weekends, occasionally it's left standing for a couple of weeks. When parked up at home I always use a Ctek charger to charge and condition the battery. It's plugged in through the 13 pin tow socket so a doddle to connect.
 Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #588215 28th Dec 2016 5:56pm
