Home > Maintenance & Modifications > Battery failing? |
AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1035 |
My 110 XS SW is about 18 months olds. About 6 months ago, I left the inside light on and flattened the battery. All appears to work OK, but lately if I start the engine, reverse out of the garage, then turn off, I get a warning sound when I start the engine for the 2nd time.
I understand that this is a battery warning. Looking at my tracker data, the battery had been dropping down to about 12.2V. Charges at 14V, then drops to about 13-13.5V when stopped again. Is the battery failing, or is it just the cold weather? Seems like very short battery life, but I may have damaged the battery when it was discharged by the internal light. |
28th Dec 2016 1:53pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3645 |
take it off give it a good shake refit and charge for several hours it will probably be fine for a good few years DEFENDER 90 TDCI XS,
28th Dec 2016 5:36pm |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2531 |
I normally only use my Defender at weekends, occasionally it's left standing for a couple of weeks. When parked up at home I always use a Ctek charger to charge and condition the battery. It's plugged in through the 13 pin tow socket so a doddle to connect.
Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
28th Dec 2016 5:56pm |
