Home > Puma (Tdci) > odb port |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2027 |
Are you sure it's another OBD port ?
I thought that some wiring looms had a connector for a Sub woofer under the cubby box ? |
26th Dec 2016 10:07pm |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3461 |
Could a previous owner have moved the OBD port for security reasons? The one under the dash could be a dummy?
Sorry, might have blown a level of security on your truck |
26th Dec 2016 10:51pm |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4785 |
+1 for sub woofer connection if it's a later puma 2002 90 Td5 Station Wagon
26th Dec 2016 10:59pm |
Trundlebus Member Since: 15 Jul 2014 Location: Herts Posts: 95 |
Well i bet you are right re sub woofer. I only saw the "port" a year or so ago when i fitted the cubby box and sort of assumed that a big thick cable wirh a huge connector was a diagnostic port. I guess i was wring!
Thanks for the input, will have to cut a hole in the fuse fanel door after all |
26th Dec 2016 11:33pm |
Could you not remove the obd port from the metal cradle and plug in the scangauge out of the way to prevent having to cut the dash? 2002 90 Td5 Station Wagon
26th Dec 2016 11:36pm |
Grafty,
I looked at moving the port but i don't think there is enough room to put the box in. It is an ultragauge blue so a bit baulky. Also it migh be handy to be able to see the indicator lights and get at the button on it without having to remove the dash cover and retrive it from the depths. Btw the ultraguage works well i just have to work out what all this extra info means. Cheers |
27th Dec 2016 9:10am |
