Home > Puma (Tdci) > odb port
Trundlebus
odb port
Hi all,
can anyone help explain why I seem to have two diagnostic ports? One is under the dash on the drivers side, where I expected but I seem to have another between the seats under where the plastic tray/cubby box sits. Now of they may be for entirely different purposes but I would like to know if i can connect an ultra gauge to either of them.
any advice appreciated
Thanks
Post #587675 26th Dec 2016 2:09pm
DAZ110
Are you sure it's another OBD port ?
I thought that some wiring looms had a connector for a Sub woofer under the cubby box ?
Post #587821 26th Dec 2016 9:07pm
Rashers
Could a previous owner have moved the OBD port for security reasons? The one under the dash could be a dummy?
Sorry, might have blown a level of security on your truck Embarassed
Post #587838 26th Dec 2016 9:51pm
grafty99
+1 for sub woofer connection if it's a later puma Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #587844 26th Dec 2016 9:59pm
Trundlebus
Well i bet you are right re sub woofer. I only saw the "port" a year or so ago when i fitted the cubby box and sort of assumed that a big thick cable wirh a huge connector was a diagnostic port. I guess i was wring!
Thanks for the input, will have to cut a hole in the fuse fanel door after all
Post #587861 26th Dec 2016 10:33pm
grafty99
Could you not remove the obd port from the metal cradle and plug in the scangauge out of the way to prevent having to cut the dash? 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #587862 26th Dec 2016 10:36pm
Trundlebus
Grafty,
I looked at moving the port but i don't think there is enough room to put the box in. It is an ultragauge blue so a bit baulky. Also it migh be handy to be able to see the indicator lights and get at the button on it without having to remove the dash cover and retrive it from the depths.
Btw the ultraguage works well i just have to work out what all this extra info means.
Post #587907 27th Dec 2016 8:10am
