Home > Technical > Indicator bolts
AdamGT3
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Corris Grey
Indicator bolts
Hi
I had to change my headlight bulbs today on a Puma.
On removing the indicators/sidelights some of the bolts/washers were missing so that each is only held on by one screw. What are the part numbers.descriptions for the bolts/washers that clip to the bodywork for the screws to grip to?
Also what siz/type are the screws for the indicators (long) and headlamps(short)?
Thanks
Adam
Post #587748 26th Dec 2016 5:40pm
Martin
Site Admin
The plastic captive nut is RTC3745
The long screws are No 6 x 1.25" (3.5mm x 32mm)
Which headlight screws do you mean? The ones which hold the rim to the headlamp?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #587781 26th Dec 2016 7:15pm
AdamGT3
Hi
Well all of them actually.
I just replaced the bulb in the headlamp and on the off side there were only 2 screws (not the 4 that there should be which were all there on the near side). Firstly, what are the 4 screws that hold the headlamp unit to the body, then all of the others as the frame is completely rusted so will need to get some stainless ones and Wipac bowls!
Thanks
Adam
Post #587919 27th Dec 2016 8:59am
Martin
Site Admin
I think the Nakatanenga stainless kit is the only one for the headlamps
http://www.4x4overlander.com/product/nakat...ng-kit-ss/  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #587923 27th Dec 2016 9:12am
