![]() | Home > Technical > Indicator bolts |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
The plastic captive nut is RTC3745
The long screws are No 6 x 1.25" (3.5mm x 32mm) Which headlight screws do you mean? The ones which hold the rim to the headlamp? ![]() ![]() |
AdamGT3 Member Since: 18 Oct 2016 Location: Beaconsfield Posts: 22 ![]() ![]() ![]() |
Hi
Well all of them actually. I just replaced the bulb in the headlamp and on the off side there were only 2 screws (not the 4 that there should be which were all there on the near side). Firstly, what are the 4 screws that hold the headlamp unit to the body, then all of the others as the frame is completely rusted so will need to get some stainless ones and Wipac bowls! Thanks Adam |
I think the Nakatanenga stainless kit is the only one for the headlamps
http://www.4x4overlander.com/product/nakat...ng-kit-ss/ ![]() ![]() |
