Home > Puma (Tdci) > How to undo the belt tensioner?
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Title says it all, pretty much, the WSM says "rotate the accessory drive belt tensioner clockwise" but how?... I don't have much grip on it...
Cheers! “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #586718 21st Dec 2016 12:27pm
o4dn
Ah nevermind, I managed to undo it... “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #586723 21st Dec 2016 12:52pm
ickle
1/2 square drive extension and bar through the 1/2" hole IIRC
Post #586724 21st Dec 2016 12:56pm
agentmulder
Kuwait
^^ 3/8" maybe? Solved the bowel problem, working on the consonants...
Post #586782 21st Dec 2016 6:10pm
ickle
You could be correct - I think I used a 1/2 bar for leverage with a 3/8 adapter on the end......
Post #586783 21st Dec 2016 6:13pm
agentmulder
Kuwait
Yeah pretty sure that's it Thumbs Up
I knew there was a reason i bought an adaptor, but for the life of me couldn't remember why the other day! Solved the bowel problem, working on the consonants...
Post #586799 21st Dec 2016 6:46pm
o4dn
" it is Thumbs Up “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #586812 21st Dec 2016 7:31pm
agentmulder
Kuwait
Maybe there are different castings/parts?
I'm now 99% sure mine is 3/8", check the sticky in this forum re. serpentine belt change. Solved the bowel problem, working on the consonants...
Post #586816 21st Dec 2016 7:45pm
o4dn
Yeap, you're absolutely right of course, I used the 3/8" adapter that I found in the torque wrench box... My bad!
Sorry for the confusion! “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #586826 21st Dec 2016 8:46pm
Dieselhead
I used a large pair of stilsons Whistle Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #587278 23rd Dec 2016 9:11pm
