![]() | Home > Td5 > 2001 TD5 90 Front brake pistons and seal question |
MC84 Member Since: 22 May 2016 Location: Near Bristol Posts: 360 ![]() ![]() ![]() |
Hi, I'm looking to replace my front pistons and seals on my 4 pot calipers. I looked on the site and have found some useful information but cannot find the part numbers for the pistons or seals. Could anyone point me in the direction of the correct parts please. As recommended I only want genuine Lockheed parts and ideally stainless pistons. The VIN (well the last part) is 1Axxxxxx
Thanks in advance Mike Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1809 ![]() ![]() ![]() |
Zeus for your stainless pistons
Seal kits from Britcar? Don't forget the red brake grease for assembly |
Don't forget these if you plan to split the calipers
http://www.brit-car.co.uk/product.php/7832..._seals_rrc your kit of parts for one side front caliper + link parts Pressure Seal x 4 Wiping Seal x 4 Retainer Ring x 4 you shod have 46mm diameter pistons in your calipers |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Don't split them, no need, just more fuss.
You're after parts 15 and 16 here: https://www.landroverworkshop.com/diagrams...iscs_52911 Not sure which relates to your year though! Oh, and there aint no thing as Lockheed or genuine pistons in stainless Solved the bowel problem, working on the consonants... |
Thanks Guys
![]() ![]() Hard Top 90 TD5 2001 Ford 100e 1959 www.youtube.com/mikemakesit |
