Home > Td5 > 2001 TD5 90 Front brake pistons and seal question
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
Hi, I'm looking to replace my front pistons and seals on my 4 pot calipers. I looked on the site and have found some useful information but cannot find the part numbers for the pistons or seals. Could anyone point me in the direction of the correct parts please. As recommended I only want genuine Lockheed parts and ideally stainless pistons. The VIN (well the last part) is 1Axxxxxx
Thanks in advance Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #586393 19th Dec 2016 6:52pm
ickle
Zeus for your stainless pistons
Seal kits from Britcar?
Don't forget the red brake grease for assembly
Post #586432 19th Dec 2016 9:27pm
dorsetsmith
Don't forget these if you plan to split the calipers
http://www.brit-car.co.uk/product.php/7832..._seals_rrc
your kit of parts for one side front caliper + link parts
Pressure Seal x 4
Wiping Seal x 4
Retainer Ring x 4
you shod have 46mm diameter pistons in your calipers
Post #586482 20th Dec 2016 8:00am
agentmulder
Kuwait
Don't split them, no need, just more fuss.
You're after parts 15 and 16 here:
https://www.landroverworkshop.com/diagrams...iscs_52911
Not sure which relates to your year though!
Oh, and there aint no thing as Lockheed or genuine pistons in stainless Solved the bowel problem, working on the consonants...
Post #586491 20th Dec 2016 8:37am
MC84
Thanks Guys Thumbs Up Thumbs Up Mike
Ford 100e 1959
Post #586693 21st Dec 2016 8:20am
roel
It is not needed to split the calipers to get the pistons out, so if there is no reason to split them don't do it.
If you have some completely worn brake pads or something that has the thickness of the metal part of the brake pads put them in instead off your brakepads and pump the brakes to get the pistons out as far as possible before you take the calipers off. This way you can easily get the pistons out. Roel
2003 90 Td5 (2009-now)
Post #586709 21st Dec 2016 10:38am
