Home > Maintenance & Modifications > Mud rails changed for Nakatanenga
mick
Having fitted the Exmoor extended seat base it lifted me up to much so decided to get the Nak ones
I don't know if it was that I had a hard day but the Mud rails are a 5 min job but seemed to take ages to fit the Nak ones fiddling with washers and nuts under the rail when it's fitted Wink reckon some captive nuts would be better like the mud rails or even a bit of flat bar welded on & drilled and tapped Thumbs Up
Post #585946 18th Dec 2016 12:10am
Sulisuli
Mick has it made a noticeable difference to the seating position by doing the exchange? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #585949 18th Dec 2016 12:15am
mick
Yup goes back just as far but a lot lower down so much improved visibility wise
Post #585950 18th Dec 2016 12:20am
Sulisuli
Thanks for the info. Did you fit the premium rail extensions? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #585952 18th Dec 2016 12:23am
mick
Post #585965 18th Dec 2016 12:55am
Sulisuli
Thanks for the link Mick, trying to find a comfortable seating position in a defender is like looking for the holy grail then just when you think you have found it the wife borrows the defender and moves the seat Laughing so these may certainly help. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #585967 18th Dec 2016 12:58am
sherifsalem
Portugal 2005 Defender 90 Td5 ST Java Black
Hi gents,
Mick is right the rails in my opinion need to be adjustable and the ones of paddock worked fine as you can regulate the height and inclination which is advisble.
Even if you are not tall or big the upgrade in seating position is noticable on command & and control.
my fitting experience:
https://thegippo.wordpress.com/2016/09/27/...78-review/ Happy Travel
www.thegippo.wordpress.com
Post #586328 19th Dec 2016 1:07pm
BigWheels
Being tall, but wanting to keep the OE steering wheel, I am interested in lower height rails. No rails and XS seat just give the safe gap. However I feel that a more padded seat would be better, so need no height but more backwards slide. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #587574 25th Dec 2016 4:26pm
