Home > Maintenance & Modifications > Boost Pin for 200tdi
CarMan
Good idea for a little more get up and go without too much effort or not? Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
2016 2.2 XS 90 hard-top (sold)
Post #585603 16th Dec 2016 3:57pm
jst
i think not personally if you mean buying a new one.
just rotate the one you have and adjust the top smoke screw, it needs doing with care and only adjust one thing at a time and drive it after each adjustment to check your performance/black smoke/EGT
also worth taking the wastegate feed from the back of the inlet manifold. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #585635 16th Dec 2016 6:22pm
roel
Like JST said, you can get a lot with the standard pin and the standard pin is fine tunable. The boostpin is a fixed thing so wouldn't be my choise.
And remember ther are 4 things you can adjust on your pump and the pin rotating is only one off them. Twisted Evil
And also like jst said moving the wastgate feed can help you not to loose 0,3 bar turbo pressure at high rpms. Roel
2003 90 Td5 (2009-now)
Post #585677 16th Dec 2016 9:20pm
CarMan
Thanks guys, enough said Cool
Post #585681 16th Dec 2016 9:42pm
