Home > Maintenance & Modifications > Having trouble filling up my 110 XS Landmark
Jimmoore
Scotland 2016 Defender 110 Puma 2.2 Landmark LE Santorini Black
Whenever I go to the filling station, regardless of the pump/station I visit, the fuel filling nozzle always seems to click off really easily and it takes an age to get any fuel into my 2016MY Defender 110.
Rather than getting fuel in full flow, I have to gently squeeze it in which makes for a longer filling up time.
Any ideas? Genuine issue or Defenderism?
Is there a technique I should be learning?
Post #585481 15th Dec 2016 11:41pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Don't insert the nozzle fully into the filler hole ( I know how that sounds)
Post #585483 15th Dec 2016 11:58pm
agentmulder
Kuwait
I get this sometimes, even after replacing the fill breather.
As above, rejig the nozzle ... Solved the bowel problem, working on the consonants...
Post #585493 16th Dec 2016 1:17am
Yup, just the tip Shocked then stop as the gurgling gets intense. Exclamation
Post #585498 16th Dec 2016 6:06am
shaun6
Turn the nozzle upside down
Post #585519 16th Dec 2016 8:25am
agentmulder
Kuwait
Post #585520 16th Dec 2016 8:31am
mattp
Australia 2016 Defender 110 Puma 2.2 SW Santorini Black
The automatic cut-off on the nozzle is triggered by the bend in the fuel pipe, so as others have said just pull back a few centimetres and you should be able to go full steam ahead.
Post #585702 17th Dec 2016 1:40am
miker
Some pumps are a bit sensitive, but usually a different angle fixes that. Most of the time I wedge the filler cap under the handle, try to not look at the numbers and wait for the click!
Post #585703 17th Dec 2016 2:01am
Jimmoore
Mr. Green some great ideas and comments in here. Very Happy
I'll be sure to try some of these techniques out next time I am at the pump.
Post #586115 18th Dec 2016 4:50pm
Never had any issues with mine, so just to be certain have you actually looked at the piping closely to check for any issues?
Post #586148 18th Dec 2016 6:41pm
