Home > Maintenance & Modifications > Having trouble filling up my 110 XS Landmark |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
Don't insert the nozzle fully into the filler hole ( I know how that sounds)
15th Dec 2016 11:58pm |
I get this sometimes, even after replacing the fill breather.
As above, rejig the nozzle ... Solved the bowel problem, working on the consonants... |
16th Dec 2016 1:17am |
Yup, just the tip then stop as the gurgling gets intense.
16th Dec 2016 6:06am |
shaun6 Member Since: 06 Mar 2013 Location: Houghton Regis, beds Posts: 46 |
Turn the nozzle upside down
16th Dec 2016 8:25am |
16th Dec 2016 8:31am |
mattp Member Since: 24 Aug 2015 Location: Melbourne Posts: 38 |
The automatic cut-off on the nozzle is triggered by the bend in the fuel pipe, so as others have said just pull back a few centimetres and you should be able to go full steam ahead.
17th Dec 2016 1:40am |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1764 |
Some pumps are a bit sensitive, but usually a different angle fixes that. Most of the time I wedge the filler cap under the handle, try to not look at the numbers and wait for the click!
17th Dec 2016 2:01am |
Jimmoore Member Since: 26 Jul 2015 Location: Scotland Posts: 161 |
some great ideas and comments in here.
I'll be sure to try some of these techniques out next time I am at the pump. |
18th Dec 2016 4:50pm |
Never had any issues with mine, so just to be certain have you actually looked at the piping closely to check for any issues?
18th Dec 2016 6:41pm |
