Home > Puma (Tdci) > Puma Easy Clutch solutions
dilukabey
2009 Defender 110 Puma 2.4 SW Keswick Green
I know the redbooster is an option but don't want to throw £375. When I search the net found that there are some other economical ways to ease the clutch pedal pressure in defenders but I really don't know the compatibility with puma as they have been used with 200tdi and 300tdi or td5. According to forums, defender v8 slave cylinder is an option but don't know the compatibility with puma. And other method is to use Lockheed LE72696 brake servo again don't know the compatibility with puma.
http://forums.lr4x4.com/topic/89939-remote...es-please/
Appreciate if somebody could provide any information on possible ways to reduce the puma clutch pedal pressure. Cheers.
Post #585354 15th Dec 2016 5:34pm
Are you certain yours is normal & you are not looking for a solution that could be fixed by replacing or fixed a standard part?
Post #585355 15th Dec 2016 5:42pm
dilukabey
[img]https://www.defender2.net/gallery/albums/userpics/11849/normal_20160430_103412~0.jpg[/img]
Hi Supacat,
I don't mind whether its a standard part or a non LR part as long as its a reliable way of easing the clutch pedal.
This picture was one of my mates puma easy clutch modification which i have posted couple of months ago. It seems its a non puma master clutch fitted with T junction such that the clutch sensor still works. Please refer the link below.
http://www.defender2.net/forum/topic46075.html
I understand that this mod is a non LR but is this a reliable and safe way to do?
Welcome any comments. Cheers.
Post #586094 18th Dec 2016 3:11pm
Sorry I'm not sure I made myself clear - is your issue a result of a poor/damaged setup; or does it work perfectly but is just too stiff for you?
Every puma I've driven has not had what I would remotely describe as a stiff clutch; but my girlfriend might say differently.
Post #586108 18th Dec 2016 4:28pm
dilukabey
Well my clutch works perfectly alright but as every other defender the clutch is generally stiff. I have been living with it now more than 5 years and thought it's the right time to give my left leg a "rest".
Post #586110 18th Dec 2016 4:34pm
