![]() | Home > Puma (Tdci) > SVX subwoofer install |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 ![]() ![]() ![]() |
It certainly says it is;
"The Clarion® SRV313 sub-woofer is located on the cabin floor below the center cubby box and is secured to the floor with two self-tapping screws." Interesting, I've been looking for a safe way to hide one for a while, I would guess the cubby box has a false bottom? Can you share where you have sourced the sub from? |
Wilco Direct have them for £59.99, I've just ordered one.
http://www.wilcodirect.co.uk/index.php?mai...ts_id=9273 |
CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947 ![]() ![]() ![]() |
If it is only the sub that is extra on an svx I would all to get one as the sound from the svx unit is really good.
Might there be an amp some where ? CR |
It's a powered sub, so has a built in amp, the workshop manual doesn't mention an additional amp for the other speakers.
So far as mounting goes, it looks like there are a couple of brackets that go around the sub to support the cubby box (see page 914), I'll have a go at making some up and post pics of the job. |
SVX90 Member Since: 31 Aug 2009 Location: Dubai Posts: 38 ![]() ![]() |
I own an SVX and the sound quality is beyond horrible...
SVX90 - any chance you can post a photo of the sub in place under the cubby box please.
5wh Member Since: 01 Jan 2011 Location: Lancashire Posts: 37 ![]() ![]() ![]() |
Dont bother.
The Sub takes up a good chunk of the cubby and just booms and booms.If you put your phone in one of the drinks holders then the sub picks the signals up and the noise drives you mad. First thing I did when I bought my SVX SW was junk the sound system and I fitted a Becker Cascade 7944,IPOD adaptor and two amps to power a pair of 6x9 speakers behind in rear seats in enclosures,and 6x9 woofers under the front seats.I replaced the dash speakers with Kenwood units and the sound is now just about bearable. 2009 SVX 90 Station Wagon |
jav-uk Member Since: 29 Mar 2010 Location: Shropshire Posts: 112 ![]() ![]() ![]() |
I fitted the Clarion SVX Sub into my XS cubby box. Took a bit of tinkering to do but was worth the effort in my opinion.
I will post some pics of how I did it if anyone is interested. I do agree with 5wh, I had to add some 6X9's to the rear to boost the midrange because the factory fit speakers just couldn't hack it once the sub was installed. Paul Paul Pondering a New 90 Commercial 2020 Evoque * 2014 110 SW JE Stage 2. *2010 110 Utility. JE Stage 2. *2007 110 SW *2003 90 JE Stage 2. *2000 90 SW If its not leaking it ain't full. |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
Thanks guys. Theres some really useful information there. Im glad I didnt just dive in and buy one and fit it. Maybe it would be better fitting it to the back of the cubby then (facing into the load space).
Pete |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
I would not want to pay and fit the standard SVX sound system,,, would be disappointed with the quality
I had to look twice to see if mine was working !!! The cubby has a false floor, (and false front for the matter for the interior lamps) that rob a fair bit of room,, Pic of the unit with the cubby removed ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Main Brian James Trailer Dealer for South West UK |
defendertom Member Since: 20 Jan 2011 Location: gwent Posts: 29 ![]() ![]() ![]() |
I CAN GET A GENUINE SVX CUBBY BOX AMP SPEAKERS AND HEAD UNIT FOR 850 IF ANYONE IS INTERESTED. ALSO COMES WITH PROPPER LOOM svx tdci (project)
200tdi 90 90 tdci truck cab 90 TD5 green lane 200tdi 100inch trayback |
rick Member Since: 07 Mar 2008 Location: Perth Posts: 133 ![]() ![]() ![]() |
Safety issues aside, has anyone tried putting tubular subwoofers up against the curve of the roof (just past the alpine window towards the rear)?
Cheers, Rick 1998 RR HSE 2007 RRS TDV6 2008 Defender 110 2015 Discovery Sport |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 ![]() ![]() ![]() |
Doesn't that unit bake with the heat from the gearbox!? ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Most probably, when a few miles have been done,, as i said, did not rate the sound quality that much better than the std XS spec set up anyway California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
