Home > Puma (Tdci) > SVX subwoofer install
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Morning all,
Has any one any pics of the installation of the Clarion subwoofer in an SVX? I want to add some bass to the stereo in my XS and have found where to buy the exact subwoofer kit from, I would just like to replicate the SVX install. DG's PDF manual seems to show it underneath the cubby, but I'm sure it's not there.
Pete
Post #58432 11th Feb 2011 11:34am
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
It certainly says it is;
"The Clarion® SRV313 sub-woofer is located on the cabin floor below the center cubby box and is secured to the floor with two self-tapping screws."
Interesting, I've been looking for a safe way to hide one for a while, I would guess the cubby box has a false bottom?
Can you share where you have sourced the sub from?
Post #58452 11th Feb 2011 12:54pm
iruffell
Wilco Direct have them for £59.99, I've just ordered one.
http://www.wilcodirect.co.uk/index.php?mai...ts_id=9273
Post #58468 11th Feb 2011 1:54pm
CR
Ireland 2011 Defender 110 Puma 2.4 CSW Santorini Black
If it is only the sub that is extra on an svx I would all to get one as the sound from the svx unit is really good.
Might there be an amp some where ?
CR
Post #58480 11th Feb 2011 2:17pm
iruffell
It's a powered sub, so has a built in amp, the workshop manual doesn't mention an additional amp for the other speakers.
So far as mounting goes, it looks like there are a couple of brackets that go around the sub to support the cubby box (see page 914), I'll have a go at making some up and post pics of the job.
Post #58481 11th Feb 2011 2:23pm
SVX90
United Arab Emirates
I own an SVX and the sound quality is beyond horrible...
Post #58482 11th Feb 2011 2:28pm
iruffell
SVX90 - any chance you can post a photo of the sub in place under the cubby box please.
Post #58486 11th Feb 2011 2:49pm
5wh
England 2009 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Dont bother.
The Sub takes up a good chunk of the cubby and just booms and booms.If you put your phone in one of the drinks holders then the sub picks the signals up and the noise drives you mad.
First thing I did when I bought my SVX SW was junk the sound system and I fitted a Becker Cascade 7944,IPOD adaptor and two amps to power a pair of 6x9 speakers behind in rear seats in enclosures,and 6x9 woofers under the front seats.I replaced the dash speakers with Kenwood units and the sound is now just about bearable. 2009 SVX 90 Station Wagon
Post #58489 11th Feb 2011 3:04pm
jav-uk
England 2014 Defender 110 Puma 2.2 SW Alpine White
I fitted the Clarion SVX Sub into my XS cubby box. Took a bit of tinkering to do but was worth the effort in my opinion.
I will post some pics of how I did it if anyone is interested.
I do agree with 5wh, I had to add some 6X9's to the rear to boost the midrange because the factory fit speakers just couldn't
hack it once the sub was installed.
Paul Paul
Pondering a New 90 Commercial
2020 Evoque
* 2014 110 SW JE Stage 2.
*2010 110 Utility. JE Stage 2.
*2007 110 SW
*2003 90 JE Stage 2.
*2000 90 SW
If its not leaking it ain't full.
Post #58512 11th Feb 2011 5:40pm
XS Pete
Thanks guys. Theres some really useful information there. Im glad I didnt just dive in and buy one and fit it. Maybe it would be better fitting it to the back of the cubby then (facing into the load space).
Pete
Post #58514 11th Feb 2011 5:47pm
TJ101
I would not want to pay and fit the standard SVX sound system,,, would be disappointed with the quality
I had to look twice to see if mine was working !!!
The cubby has a false floor, (and false front for the matter for the interior lamps) that rob a fair bit of room,,
Pic of the unit with the cubby removed
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #58519 11th Feb 2011 6:07pm
defendertom
Wales 2011 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
SVX SOUND SYSTEM
I CAN GET A GENUINE SVX CUBBY BOX AMP SPEAKERS AND HEAD UNIT FOR 850 IF ANYONE IS INTERESTED. ALSO COMES WITH PROPPER LOOM svx tdci (project)
200tdi 90
90 tdci truck cab
90 TD5 green lane
200tdi 100inch trayback
Post #60494 22nd Feb 2011 1:06am
rick
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Tubular sub-woofers
Safety issues aside, has anyone tried putting tubular subwoofers up against the curve of the roof (just past the alpine window towards the rear)?
Cheers,
Rick 1998 RR HSE
2007 RRS TDV6
2008 Defender 110
2015 Discovery Sport
Post #60498 22nd Feb 2011 5:39am
Naks
TJ101 wrote:
The cubby has a false floor, (and false front for the matter for the interior lamps) that rob a fair bit of room,, Pic of the unit with the cubby removed
Doesn't that unit bake with the heat from the gearbox!? Shocked --
Post #60510 22nd Feb 2011 7:58am
TJ101
Most probably, when a few miles have been done,, as i said, did not rate the sound quality that much better than the std XS spec set up anyway California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #60521 22nd Feb 2011 8:25am
