Home > Technical > Heating problems
jesperjes
2002 Defender 110 Td5 DCPU Java Black (black Hood)
Heating problems
My 2002 110" TD5 is having cooling issues.
When I turn on the heat in the cabin there is no hot air coming out it's cold. And the reason for this is that the coolant hose going in to the heater matrix is cold even though the engine is at the right temperature. If I drive 90 km/h in 4th gear there's hot air coming in to the cabin if I shift to 5th gear the hot air disappears. If I drive in the city there is also no hot air.
The car runs just fine and the temperature gauge is at the right place all the time.
If I use the Webasto car heater while parked, hot air is coming in to the cabin and the engine gets hot as usual.
When I look at the expansion tank I can see that coolant has been leaking through the cap (the cap is new). It seems to be from over pressure.
I have bleeded the system a thousand times.
The thermostat and water pump has been replaced with no luck. I have taken the heater matrix out and cleaned it. I have checked the hoses to and from the heater matrix and there are not blocked.
A pressure test of the cooling system showed no leaks, and the coolant is checked for exhaust gasses and there was no issues here either.
What is my next step? I have no idea where to look now......
Post #534200 24th May 2016 7:26am
Mo Murphy
Warm the engine, leave it on idle and bleed the air from the heater by slackening the jubilee clips on the heater end of the heater hoses. Allow the air to release and tighten the clip once water starts to come out.
HTH
50 Shades of Pennine Grey
Post #534209 24th May 2016 8:14am
dorsetsmith
have you checked heater box flaps working ok, is the heater matrix clean and not blocked, fan working ok
Post #534210 24th May 2016 8:15am
jesperjes
Yes the heater flaps works, the cables are adjusted correctly, the heater matrix is clean and not blocked, fan works.
When I push the engine a little extra everything works just fine.
I'll think I have tried bleeding through the heater hoses as Mo Murphy mentions, but I'll give it a try again.
Post #534216 24th May 2016 8:48am
jesperjes
No luck bleeding through the heater hoses Sad
Post #534450 25th May 2016 7:51am
Triple7
United Kingdom 2004 Defender 90 Td5 SW Oslo Blue
Re: Heating problems
jesperjes,
Did you ever get this issue sorted? Our TD5 never seems to get HOT air from the heater Sad
Post #584957 14th Dec 2016 9:06am
jesperjes
No I didn't. I have sold the car.
I'm pretty sure the only answer is faulty head gasket in my case.
If you run the car for 5 min and you remove the cap from the expansion tank is there over pressure in the system? I had that, and therefore I think the over pressure is from exhaust getting in the cooling system through the faulty head gasket. All of this exhaust goes to the highest point in the system (heater matrix) and therefore no hot coolant water will access the heater and allow hot air in the cabin.
I'm not an expert that's just my theory Smile
Post #584962 14th Dec 2016 9:53am
Triple7
Thanks for the reply
I'll have to do some further investigation next time I get chance
Post #584975 14th Dec 2016 11:04am
