Home > Technical > Leaking vacuum pump gasket - Puma 2009 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17372 |
I would change both, and I don't remember it being at all difficult.
13th Dec 2016 9:08am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20348 |
Many just replace the gasket, or you could change both as suggested above.
IIRC, the coupling is a pain in the backside to remove on the pipe. Removal other than that is easy, and easy access, replace fixings and torque to WSM specs. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
13th Dec 2016 10:19am |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 538 |
Parts ordered, thanks! “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
-- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
13th Dec 2016 2:50pm |
vaucluse Member Since: 04 Feb 2012 Location: SE London Posts: 185 |
it may be the single seal behind the pulley on the vacuum pump itself - new one is modified and has a double seal
Mark |
13th Dec 2016 3:40pm |
Seal failure tends to blow oil all over the engine bay and is fairly unmistakable.
13th Dec 2016 4:00pm |
Yes, it's what I thought, it's not the case here, just a small-ish oil leak underneath the vacuum pump.
Nevertheless I ordered a new pump, gasket and ancillary belt, while at it... “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
13th Dec 2016 4:04pm |
By undoing the brass nut (in yellow) below? Or how...
I removed the old pump by undoing the brass nut to disconnect the vacuum pipe, but then there is a new brass nut already in place on the new pump, so I am not sure I did right... Should I just remove the new one and refit the old brass nut connected to the vacuum pipe? “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
21st Dec 2016 6:10pm |
The nut stays in place. You fiddle about with the collar that is round the pipe where it emerges from the nut, and after a while the pipe miraculously comes free, even though you're not really sure what you did.
At least that is how it was for me. |
21st Dec 2016 6:41pm |
Blackwolf, brilliant, as usual
You help on this forum is truly invaluable, many thanks!! “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
21st Dec 2016 6:49pm |
